Solved by Jake90087
Why not have a new transponder coded up from a specialist that does these things? The thing I would say is the ECU swap could result in mileage errors or other issues. But I am no expert really.
Get two done. If you have two keys you can code your own, then you can have a basic key cut, code it yourself and have three for if you lose one (or more). Since my car came with two, It made sense. Why are you changing the locks on your car also?
Sent from my iPhone 6 using Ford OC mobile app
  • Solution
Can you code your own without the red key?
If you have two keys, yes. Ford stopped supplying red keys after the 1998 model year. There's a how to in the manual, If you don't have yours I'll post a pic of mine when I go out later.
My apologies for taking so long to upload, been a busy week but here t is from the manual. post-44686-142071558013_thumb.jpg
