FrozenWhiteZetecS Posted January 29, 2015 Share Posted January 29, 2015 I've just bought a K&N panel filter for my zetec S 2014, acceleration is worse after I installed it and response in the car feels weird. I've read that the oil from the filter is very bad for the small turbo, is that true? Can I remove the red oil and mount the filter again? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Willy Posted January 29, 2015 Share Posted January 29, 2015 Shouldn't make any difference with the filter fitted as mountune supply them with there remap. Did you take any of the pipe work apart or remove the air flow sensor? I'd also consider disconnecting the battery. Quote Link to comment Share on other sites More sharing options...
FrozenWhiteZetecS Posted January 29, 2015 Author Share Posted January 29, 2015 No pipework was taken apart, nether the airflow sensor, should I remove that? What do you mean with disconnecting the battery? Should I disconnect it and put it on again? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Willy Posted January 29, 2015 Share Posted January 29, 2015 Disconnecting the battery resets the ecu. It won't erase anything. That should be all you need to do. Replacing your filter shouldn't make much difference to the car other than give you a slightly deeper engine note a full throttle. Quote Link to comment Share on other sites More sharing options...
FrozenWhiteZetecS Posted January 29, 2015 Author Share Posted January 29, 2015 Okay, I will try to do that tomorrow :-) Thanks Willy! Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Ffoxy Posted January 29, 2015 Share Posted January 29, 2015 If you got filter oil on the MAF it will damage it. They are very hard to clean successfully. Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
FrozenWhiteZetecS Posted January 30, 2015 Author Share Posted January 30, 2015 I will try to clean the MAF today, if it isn't working then i will probably have to buy a new one. Do i need to disconnect the battery while cleaning MAF sensor? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Ffoxy Posted January 30, 2015 Share Posted January 30, 2015 It should come out really. Don't touch anything with a cloth or paper. Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
FrozenWhiteZetecS Posted January 30, 2015 Author Share Posted January 30, 2015 I know, I will use some 99% isoprophyle alcohol to spray it with. Do you know if i need to disconnect the battery while cleaning? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Ffoxy Posted January 30, 2015 Share Posted January 30, 2015 I always have when replacing them but I never replaced an Ecoboost version. If I had to guess I would disc the battery. Better safe than sorry. Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
FrozenWhiteZetecS Posted January 30, 2015 Author Share Posted January 30, 2015 I just rinsed the MAF with electric contact cleaner and afterwards I soaked it in 99% isoprophyle alcohol. Results are great! car runs as new, lost power is restored an car runs more smooth now and sounds more quiet, thanks for the help mates. :) Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Willy Posted January 30, 2015 Share Posted January 30, 2015 Good news :) Quote Link to comment Share on other sites More sharing options...
Ffoxy Posted January 30, 2015 Share Posted January 30, 2015 Cool Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
FrozenWhiteZetecS Posted January 30, 2015 Author Share Posted January 30, 2015 The question now is if it is a good idea to put the K&N Panel without oil in again or leave it standard until i get induction kit without pre-oiled filter ? :) Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Ffoxy Posted January 30, 2015 Share Posted January 30, 2015 I'm staying with the standard filter. Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
iantt Posted January 30, 2015 Share Posted January 30, 2015 unless you have altered the mapping of your ecoboost then putting in kn filter wont make any difference to your car, stick with a standard filter replaced at 37.5k intervals. Quote Link to comment Share on other sites More sharing options...
