Mk7 Interior Fan Speed
Fan speed on my MK7 Fiesta only works at the highest setting.
There is nothing at all on all the lower settings, but as soon as I crank it up to the top position, air is blasted through the car.
All routes work fine on the highest fan speed, so direction of airflow not the problem - just seems to be off when set to the lower settings - not even a breeze.
The highest setting is noisy and no good for general a/c when out and about - any ideas?
I can't see any obvious fuse problems, but then again, not really sure which fuse I should be looking at...
Thanks!
it will be the fan resistor pack that needs replacing, it a common problem.
Yep, as above, is your car still under warranty?
Thanks for the replies - not under warranty as far as I know - was bought on HP 2nd hand from a dealer and we're about 2 years in.
Now that I know what to look for, I'll research how to replace it and pay a visit to Ebay. I've had a quick look online and it looks as though it's going to be in one of the footwells - either above the clutch on driver side or in the right corner of the passenger footwell under the trim. May need to limber up before I attempt to replace it by all accounts and only test it in situ as it apparently gets a bit hot...
Thanks again - I'll let you know how I get on.
3 yrs or 60,000 miles is the warranty.whichever is the sooner.
Easy job , its passenger footwell side,
looks like this
post-59356-0-92982800-1423156266_thumb.j
Just wanted to say thanks to everyone - now sorted as a result of the advice offered here.
Thanks again.
