Tizer Posted February 3, 2023 Share Posted February 3, 2023 1 hour ago, TomsFocus said: Random question for today...anyone know what type of access cover this is? Found a broken one earlier. Thought I'd report it before someone trips on it in the dark. Turns out it's not that simple though, depends which service it's for, and I didn't check at the time. With that shape it is probably a Telephone or Cable or other low Voltage cable one. 2 1 Quote Link to comment Share on other sites More sharing options...
Zico Posted February 3, 2023 Share Posted February 3, 2023 4 hours ago, TomsFocus said: Random question for today...anyone know what type of access cover this is? Found a broken one earlier. Thought I'd report it before someone trips on it in the dark. Turns out it's not that simple though, depends which service it's for, and I didn't check at the time. Report it via your local highway online if they have a fault reporting page/tool. Any defective apparatus such as an access cover, cabinet or pole, will then be inspected and reported to the respective owner as a Section 81 defective apparatus report. From the image (Google street view?) it's either an BT or a water sluice valve cover belonging to your local water board. **edit** It looks more like the BT cover show on this page part way down: https://www.transconnect.co.uk/local loop eqpt etc/index.html 1 1 Quote Link to comment Share on other sites More sharing options...
Wino Posted February 3, 2023 Share Posted February 3, 2023 4 hours ago, TomsFocus said: Random question for today...anyone know what type of access cover this is? Found a broken one earlier. Thought I'd report it before someone trips on it in the dark. Turns out it's not that simple though, depends which service it's for, and I didn't check at the time. It could possibly be a BT box, known as a "0" box at build stage. If you lift the cover up it should have a large black plastic casing inside with a cable attached it would look like a giant liquorice torpedo. 2 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 4, 2023 Share Posted February 4, 2023 12 hours ago, Zico said: Report it via your local highway online if they have a fault reporting page/tool. Any defective apparatus such as an access cover, cabinet or pole, will then be inspected and reported to the respective owner as a Section 81 defective apparatus report. As far as I can tell, I can only report broken water drain covers through the local council website tool. And I can't even do that. They're classed as an emergency so can only be reported by telephone. Report a highways issue - Suffolk County Council 12 hours ago, Wino said: It could possibly be a BT box, known as a "0" box at build stage. If you lift the cover up it should have a large black plastic casing inside with a cable attached it would look like a giant liquorice torpedo. I can't lift it unfortunately. Will try & walk round that way again to see if there's anything written on top though. Assuming it hasn't completely caved in overnight... 16 hours ago, Tizer said: With that shape it is probably a Telephone or Cable or other low Voltage cable one. I always forget about cable in the UK. Don't think I've lived anywhere with that option so far! I know we don't have it up to the flats, but I guess could be available on the main estate. Quote Link to comment Share on other sites More sharing options...
Wino Posted February 4, 2023 Share Posted February 4, 2023 1 hour ago, TomsFocus said: As far as I can tell, I can only report broken water drain covers through the local council website tool. And I can't even do that. They're classed as an emergency so can only be reported by telephone. Report a highways issue - Suffolk County Council I can't lift it unfortunately. Will try & walk round that way again to see if there's anything written on top though. Assuming it hasn't completely caved in overnight... I always forget about cable in the UK. Don't think I've lived anywhere with that option so far! I know we don't have it up to the flats, but I guess could be available on the main estate. Report it to the council and tell them it's a trip hazard. They have to act and make it safe, then it up to them to inform BT to get it repaired. It's no more than 2 hours from start to finish to replace it like for like. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 4, 2023 Share Posted February 4, 2023 2 hours ago, Wino said: Report it to the council and tell them it's a trip hazard. They have to act and make it safe, then it up to them to inform BT to get it repaired. It's no more than 2 hours from start to finish to replace it like for like. I can't report it online as they only allow very specific categories. Emergencies have be done by telephone, which I'm not able to do. Hopefully someone else has reported it. I'll still try and walk over that way again to check though. Quote Link to comment Share on other sites More sharing options...
StephenFord Posted February 4, 2023 Share Posted February 4, 2023 2 hours ago, TomsFocus said: I can't report it online as they only allow very specific categories. Emergencies have be done by telephone, which I'm not able to do. Hopefully someone else has reported it. I'll still try and walk over that way again to check though. You should get yourself a can of yellow paint, when I was young, I always wanted a job which consisted of just spraying yellow paint around a hazard on the roads - looks fun LOL 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted February 4, 2023 Share Posted February 4, 2023 1 hour ago, StephenFord said: You should get yourself a can of yellow paint, Just like on Blue Peter, here's one I did earlier 😀 4 Quote Link to comment Share on other sites More sharing options...
Zico Posted February 4, 2023 Share Posted February 4, 2023 8 hours ago, Wino said: Report it to the council and tell them it's a trip hazard. They have to act and make it safe, then it up to them to inform BT to get it repaired. It's no more than 2 hours from start to finish to replace it like for like. Yes, HA will need to make safe (guard off the area/cones/barriers/footway board) and alert the utility to attend to repair/replace. Some are better than others at dealing with S81 reports from my experience. Had a battle with Virgin Media last year who three times denied that they had two carriageway covers in a part of West Kent. Even after supplying them with VM's own plant plans, clearing showing that they had a cable route and access points exactly where the report was, they still denied it was VM plant. After go back to them several times, they finally accepted it was VM plant and replaced the carriageway covers. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 7, 2023 Share Posted February 7, 2023 Has Mr Kipling found a way of selling mince pies in spring? 2 3 Quote Link to comment Share on other sites More sharing options...
iantt Posted February 13, 2023 Share Posted February 13, 2023 Were just about to go to bed and my partner decided to be nosey through the bedroom curtains. She said there 2 lads hiding behind the bush outside our house. She shouted at them and ran off. At that point I was getting dressed to confront them . As I was they came back again and hid behind bush again. I tooled up and went outside to confront them. Thinking they were eying up either of our cars. They had gone so I jumped in my car to cruise around looking for them . Found my daughter and her boyfriend down the road outside there car putting up posters saying happy 59th birthday all around. They were lucky I didn't clobber them around the head. 🤣🤣🤣found 10 posters on my way back home with another 20 apparently scattered about with my face on. 1 5 Quote Link to comment Share on other sites More sharing options...
unofix Posted February 14, 2023 Share Posted February 14, 2023 Well Happy 59th Birthday 🎂 What's it like to be that young? 😁 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted February 14, 2023 Share Posted February 14, 2023 7 hours ago, unofix said: Well Happy 59th Birthday 🎂 What's it like to be that young? 😁 Thanks. today 59 so far seems the same as 58 yesterday. I'm not the only one who has a birthday today on this forum. 1 1 Quote Link to comment Share on other sites More sharing options...
Wino Posted February 14, 2023 Share Posted February 14, 2023 9 hours ago, iantt said: Were just about to go to bed and my partner decided to be nosey through the bedroom curtains. She said there 2 lads hiding behind the bush outside our house. She shouted at them and ran off. At that point I was getting dressed to confront them . As I was they came back again and hid behind bush again. I tooled up and went outside to confront them. Thinking they were eying up either of our cars. They had gone so I jumped in my car to cruise around looking for them . Found my daughter and her boyfriend down the road outside there car putting up posters saying happy 59th birthday all around. They were lucky I didn't clobber them around the head. 🤣🤣🤣found 10 posters on my way back home with another 20 apparently scattered about with my face on with the words " Local nutter on the loose" written on the bottom of poster with the word WANTED in big red letters underneath 🤣 Corrected your post that you forgot to finish.....old age catching up with you already 🤣 1 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted February 14, 2023 Share Posted February 14, 2023 6 minutes ago, iantt said: Thanks. today 59 so far seems the same as 58 yesterday. I'm not the only one who has a birthday today on this forum. I suppose for years your Mrs has been rolling your Birthday present up in the same bag as your Valentines day gift LOL 2 Quote Link to comment Share on other sites More sharing options...
iantt Posted February 14, 2023 Share Posted February 14, 2023 24 minutes ago, Wino said: Corrected your post that you forgot to finish.....old age catching up with you already like me 🤣 I don't think I'm that wanted to warrant capital letters 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted February 14, 2023 Share Posted February 14, 2023 BBC News - Ford to cut one in five jobs in the UK https://www.bbc.co.uk/news/business-64629072 Ford are convinced that the 2030 ice ban is still going to happen 3 Quote Link to comment Share on other sites More sharing options...
unofix Posted February 14, 2023 Share Posted February 14, 2023 Does that guy still walk around London with his sandwich board "The End of the World Is Nigh" ? He must be about 130 years old by now, but he is finally right 😧 So when everything in the world is final broken (1:32PM 15th November 2043), and anarchy and revolutions are the daily norm just remember, although we will be long gone "We told you so !!" 🤔 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 14, 2023 Share Posted February 14, 2023 4 hours ago, iantt said: Thanks. today 59 so far seems the same as 58 yesterday. I'm not the only one who has a birthday today on this forum. Statistically there must be quite a few. Hope you're having a good day! Quote Link to comment Share on other sites More sharing options...
iantt Posted February 14, 2023 Share Posted February 14, 2023 23 minutes ago, TomsFocus said: Statistically there must be quite a few. Hope you're having a good day! And you. 1 Quote Link to comment Share on other sites More sharing options...
Zico Posted February 15, 2023 Share Posted February 15, 2023 I don't like that my Direct Line car insurance renewal has gone up almost £100 from last year (£408). I don't like that my manual searches with some of the big 5 star insurers (LV, Admiral, More Than, Aviva etc.) have all been higher than Direct Line with like for like coverage and options (~£570 or more) . 1 Quote Link to comment Share on other sites More sharing options...
StephenFord Posted February 15, 2023 Share Posted February 15, 2023 2 minutes ago, Zico said: I don't like that my Direct Line car insurance renewal has gone up almost £100 from last year (£408)... It's a waiting game... when you get older, 60+, it'll all start to come down! 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted February 15, 2023 Share Posted February 15, 2023 2 minutes ago, StephenFord said: It's a waiting game... when you get older, 60+, it'll all start to come down! Got another year to go then. Can't wait for my car insurance£170 to go down. Quote Link to comment Share on other sites More sharing options...
Tizer Posted February 15, 2023 Share Posted February 15, 2023 9 minutes ago, Zico said: I don't like that my Direct Line car insurance renewal has gone up almost £100 from last year (£408). I don't like that my manual searches with some of the big 5 star insurers (LV, Admiral, More Than, Aviva etc.) have all been higher than Direct Line with like for like coverage and options (~£570 or more) . The exact same thing happened to me this week. I shopped around to get other prices and phoned Direct Line querying the renewal price and they dropped it to about only 10% more than last year without any without any fuss. 1 Quote Link to comment Share on other sites More sharing options...
Zico Posted February 15, 2023 Share Posted February 15, 2023 3 minutes ago, Tizer said: The exact same thing happened to me this week. I shopped around to get other prices and phoned Direct Line querying the renewal price and they dropped it to about only 10% more than last year without any without any fuss. I'll try giving them a call before the end of the week. Did you use any particular plea/argument/I'm leaving you? I can't really say I'm off, thanks, bye as they are cheapest. Still to check the comparison sites but they've never been cheaper than checking direct, or with those companies not on the comparison sites. Quote Link to comment Share on other sites More sharing options...
