ric01 Posted February 25, 2015 Share Posted February 25, 2015 Hi, as above, the square (ish) plastic surround around the the rear seat release button is missing on my newley acquired Mondeo Mk4 estate, Can anyone tell me how to describe it properly and/or the part number, so that I can get a replacement? Thanks Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 25, 2015 Share Posted February 25, 2015 You referring to the seat switch bezel I believe. I am still trying to get microcat working as my last one expired! 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 26, 2015 Share Posted February 26, 2015 You referring to the seat switch bezel I believe. I am still trying to get microcat working as my last one expired! Change your computers date to 02/11/2014 and it will work as it's a timed expiry. Microcat will still run if you do that. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 26, 2015 Share Posted February 26, 2015 (Prices are listed in Euros) What you need is a seat latch bezel, same fit for either side however you need to be sure of the colour. Try here for your interior colour to match up correctly- http://www.etis.ford.com/vehicleRegSelector.do Enter your Vin for details of your car. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 26, 2015 Share Posted February 26, 2015 Change your computers date to 02/11/2014 and it will work as it's a timed expiry. Microcat will still run if you do that. Is that a case of set the date before running the software? Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 26, 2015 Share Posted February 26, 2015 Yes. Set to 02/11/15 and open microcat. Reset date after you finish or else websites will play up. They often get confused if you don't. If you're using VMware or any other emulator to run microcat then you only need to change the date on the virtual OS. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 26, 2015 Share Posted February 26, 2015 yeah thats what I am doing, I will give it another crack, as I changed the date after the error, which probably killed it lol Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 26, 2015 Share Posted February 26, 2015 I thought mine had died but it is purely a timed expiry. Altering the date should be enough. If need be - uninstall, remove residual files, change the date and reinstall. Quote Link to comment Share on other sites More sharing options...
ric01 Posted March 1, 2015 Author Share Posted March 1, 2015 Thanks for the info 1 Quote Link to comment Share on other sites More sharing options...
