Advice On How To Describe Issue To Garage?
Hi everyone,
I am a car novice, in that this is the first time I've owned a car that is mine, and my significant other does not drive, so cannot help me identify/describe the issue. Maybe someone can help me explain it, or let me know if my explanation is alright?
I've had my 2004 Ford Fiesta 1.4 LX Semi-automatic for just over a month. I rarely have to drive over 30mph in my general area, but today I traveled for just over half an hour, mostly between 50 and 60mph. When I got to my destination, I opened my car boot and noticed a burning smell. I popped the hood and checked all my liquid levels and they were just fine.
Heading back, I'd put the car in gear and it wouldn't move, as if I had the brake on. I double checked, and my emergency brake was back down. I pressed the gas and it was sluggish, but it moved. I came back through the same roads, but as I'd slowed down, my brakes began to make noise when I pressed them (the high-pitched whine that means uh oh...time for new brakes). As I was getting back to my area, I went to slow down to stop. I pressed the brake and it tightened, then released and went all the way down and I could feel the front brakes stop me. on and off, it would struggle. the squeal of the brakes and the sluggish, brakes seem to be engaged bit.
Luckily I was very close to home, so I limped cautiously, keeping loads of distance and gently pumping the brake to stop. Same burning smell when I got out, from the rear.
Now this seems to me that the issue has to do with the brakes (hopefully that's all!) I have brake pads on the front weels (and they look good) and brake shoes on the back. I know as of the last MOT there was slight rust on one of the brake pipes.
Should this be what I explain to the mechanic? is there something that may be a problem or am I missing some information that I should be communicating?
Thanks for any help.
ACK! Apologies for the multiple posts! My laptop was doing weird things :(
Possibly a seized brake for the smell, would also explain the not wanting to go, take it to your nearest garage and they can put it on the brake tester to quickly establish which one, or you could jack up each corner at a time and try turning them by hand and feel for a lot of resistance, best to have it done properly, brakes are for cowards but come in useful at times
It does sound like the rear shoes are binding / or handbrake cable(s) are seizing / sticking.
Thank you for the suggestions - It willd efinitely help. I'm taking my car in on Friday morning.
Just an update: It was, indeed the brake cable. It has been replaced and she's not even idling loudly, like she was before!! The guy was 'impressed' I'd guessed what it was.
Little did he know you all were my Ace up my sleeve!!
Thank you!!
