Windscreen Washer Pump
Hi All
Recently bought a 2009 Fiesta 1.4 Zetec. I am having issues where windscreen washer isn't working. I checked the water tank and it was filled with gunk. I emptied out the water, cleaned the pump and filter but no joy. So I assumed that the pump wasn't working I bought a new pump but still the same issue.
Does anybody know if there is a fuse for this? What else can be wrong?
Any help appreciated. Thank you in advance.
Clogged jets / feed tubes ?
I have cleaned out the jets and feed tubes as much as I can. When I try to use the wiper washer, both front and rear, no noise as to pump is trying?
Could be blown fuse.
Found the culprit. Thanks Mark. I thought it may have been a fuse but I didn't know that there are two fuse boxes. I checked all the fuses in the engine compartment but didn't know that there is second one in the car!!!
Good !
You're welcome :)
