msmb85 Posted March 20, 2015 Share Posted March 20, 2015 Hoping to find some help here. The headlights on my focus seam to be pointing low i work in a garage and we had the car in yesterday, there is no beam image on the headlight tester, removed the headlight bulb is seated correctly even tried a new bulb but no difference made, searched on here found a few topics but no solution please help.... Quote Link to comment Share on other sites More sharing options...
whisky Posted March 22, 2015 Share Posted March 22, 2015 I have a similar problem but only became noticeable when I replace the two head light bulbs for some Osama night vision lamps. The pattern from the beam seems very close and low and not projecting far forward. The levelling motors seem to work ok and do adjust if I move the rotary switch within the car. It's as if they need to be lifted up somehow to allow the beam to be throne forward. Quote Link to comment Share on other sites More sharing options...
jinjoh_ninjoh Posted March 22, 2015 Share Posted March 22, 2015 The adjuster is located lower down at the back of the headlights, the adjuster on top only moves them from left to right. If you get a torch and shine it behind the fitting you will see the other adjuster. I had this problem and the garage wanted me to buy two new headlights. Safe to say I did my research and fixed it for nout haha Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
jinjoh_ninjoh Posted March 22, 2015 Share Posted March 22, 2015 I hope this helps guys and is easy enough to understand Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
whisky Posted March 22, 2015 Share Posted March 22, 2015 Thanks I will give it a try when darker. Quote Link to comment Share on other sites More sharing options...
jinjoh_ninjoh Posted March 22, 2015 Share Posted March 22, 2015 If you can't find it when I get my car to my house tomorrow I will take the head light and and get some pictures for you Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
