jayteepics Posted March 21, 2015 Share Posted March 21, 2015 Is it possible to have this option retro fitted please? If not Ford, does anyone know of any after market option please? Jamie Quote Link to comment Share on other sites More sharing options...
andywil13 Posted April 5, 2015 Share Posted April 5, 2015 Is it possible to have this option retro fitted please? If not Ford, does anyone know of any after market option please? Jamie Did you find an answer to this? I have just bought a 2009 fiesta and looking to retro fit this aswell. I dont think this was even an option on the 2009 model, but i dont know if the boot design has changed with the facelift model. If the boot is exactly the same, I am hoping i can buy the parts and install myself Thanks Quote Link to comment Share on other sites More sharing options...
MarksST Posted April 5, 2015 Share Posted April 5, 2015 This was a £75 option so I would think it would be a lot more to retrofit but, it would be possible. Aswell as the floorboard you need; These hinge covers that support the rear end and alow it to hinge upwards The loading lip needs changing as it has these supports for the front edge of the floor. These catches hold the floor up when you hinge it upwards, useful but you may not find they are worth it, if you can get them seperately to the parcel shelf bracket, then it should just need a hole cutting. The wheel arch carpets are slightly different and have these dividers fitted to stop thing going under the floo and to act as cubbies, again probably not needed but would just need 2 slots cutting in the carpet for them to slot into. Quote Link to comment Share on other sites More sharing options...
andywil13 Posted April 5, 2015 Share Posted April 5, 2015 This was a £75 option so I would think it would be a lot more to retrofit but, it would be possible. Aswell as the floorboard you need; These hinge covers that support the rear end and alow it to hinge upwards The loading lip needs changing as it has these supports for the front edge of the floor. These catches hold the floor up when you hinge it upwards, useful but you may not find they are worth it, if you can get them seperately to the parcel shelf bracket, then it should just need a hole cutting. The wheel arch carpets are slightly different and have these dividers fitted to stop thing going under the floo and to act as cubbies, again probably not needed but would just need 2 slots cutting in the carpet for them to slot into. Thanks for that info - really useful - do you know if this will work on a 2009 fiesta though? I appreciate this will cost more than having done at the factory - but happy to cut corners on things like the retaining clips. Will prob just go for -adjustable floor -rear mounts -front lip Then if that works maybe do the optional bits depending on cost. big question is around the 2009 model side of things. Any idea on part numbers? I use partsbase.org for getting this info for my Audi - but as this is the first time we have a Ford in the family I haven’t found the equivalent parts database yet. Might have to test out how helpful the local Ford parts department is! Thanks Quote Link to comment Share on other sites More sharing options...
MarksST Posted April 5, 2015 Share Posted April 5, 2015 Can't see a reason why it wouldn't work. Think the ford parts system is ecat, some users on here have access to it. Ford parts should be able to find the parts easy enough. Quote Link to comment Share on other sites More sharing options...
andywil13 Posted April 5, 2015 Share Posted April 5, 2015 going to pop down to the dealer tomorrow and ask them/have a look. Whist comparing photos the boots look exactly the same, boot liners on eBay seem to either be for 2008-2012 or 2012 onwards - leading me to think perhaps there is something differnet that will throw a spanner in the works. Thanks 1 Quote Link to comment Share on other sites More sharing options...
BHeart Posted April 5, 2015 Share Posted April 5, 2015 When I was ordering my present TitX back in January, I wanted the adjustable floor and my dealer said that instead of ordering one for my new Fiesta, they could remove it from my previous a Fiesta and install it in my new car when it arrived at the dealer. I ended up leaving it in my old car and just added the option to my new car so, I think it's definitely possible and you just need to be able to buy all of the required parts. I can't really see that the boot area/floor pan in a 2009 Fiesta would be any different than it is in a 2015 model. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
jayteepics Posted April 6, 2015 Author Share Posted April 6, 2015 Andrew, Let us know what you find out at the dealer's please. Quote Link to comment Share on other sites More sharing options...
andywil13 Posted April 7, 2015 Share Posted April 7, 2015 This was a £75 option so I would think it would be a lot more to retrofit but, it would be possible. Aswell as the floorboard you need; These hinge covers that support the rear end and alow it to hinge upwards The loading lip needs changing as it has these supports for the front edge of the floor. These catches hold the floor up when you hinge it upwards, useful but you may not find they are worth it, if you can get them seperately to the parcel shelf bracket, then it should just need a hole cutting. The wheel arch carpets are slightly different and have these dividers fitted to stop thing going under the floo and to act as cubbies, again probably not needed but would just need 2 slots cutting in the carpet for them to slot into. Hi MarkST - with the clips at the back - how do they attach? do they clip on/off easily? attached with screws? Called ford today and the retrofit "kit" was like £400 but the back brackets are like £11 each just wondeirng if there is more too this than meets the eye. Thanks Quote Link to comment Share on other sites More sharing options...
MarksST Posted April 7, 2015 Share Posted April 7, 2015 Just taken the plastic cover off ( 1 screw) the hinge looks like it might be a completely different part to the standard hinge. Quote Link to comment Share on other sites More sharing options...
HarryNLD Posted April 7, 2015 Share Posted April 7, 2015 The hinge on the picture above is indeed different (#3 - picture 1). FINIS RH: 1785935FINIS LH: 1785936 Cover for the hinges: FINIS RH: 1805755FINIS LH: 1805756 Bold to secure the cover: FINIS: 4364422 And all the other parts necessary. I looked it up once, but all the parts together are quite expensive. Side trim (wheel arch) FINIS RH: 1804222 FINIS LH: 1804211 Side trim (plastic) FINIS RH: 1800032 FINIS LH: 1800034 Side cover (#3 - picture 4): FINIS RH: 1804210 FINIS LH: 1804221 Retainer: 1773686 (#3 - picture 3) Back trim: 1822310 (#3 - picture 2) Floormat: 1804234 Floorliner: 1798009 I think these are all the parts you need, couldn't find any more in Microcat :) . If you have a rubber boot mat, you need a different one. 1 Quote Link to comment Share on other sites More sharing options...
andywil13 Posted April 8, 2015 Share Posted April 8, 2015 Just taken the plastic cover off ( 1 screw) the hinge looks like it might be a completely different part to the standard hinge. Thanks Mark - bit of a shame its different under the plastic - but Harry has just posted some part numbers so not all lost. Cheers Quote Link to comment Share on other sites More sharing options...
andywil13 Posted April 8, 2015 Share Posted April 8, 2015 The hinge on the picture above is indeed different (#3 - picture 1). FINIS RH: 1785935 FINIS LH: 1785936 Cover for the hinges: FINIS RH: 1805755 FINIS LH: 1805756 Bold to secure the cover: FINIS: 4364422 And all the other parts necessary. I looked it up once, but all the parts together are quite expensive. Side trim (wheel arch) FINIS RH: 1804222 FINIS LH: 1804211 Side trim (plastic) FINIS RH: 1800032 FINIS LH: 1800034 Side cover (#3 - picture 4): FINIS RH: 1804210 FINIS LH: 1804221 Retainer: 1773686 (#3 - picture 3) Back trim: 1822310 (#3 - picture 2) Floormat: 1804234 Floorliner: 1798009 I think these are all the parts you need, couldn't find any more in Microcat :) . If you have a rubber boot mat, you need a different one. Thanks Harry - really useful info Would you be able to post the parts diagram to go with this? I have already ordered a couple of parts which now I know wont work on their own, so need to decide how much im willing to spend Cheers Quote Link to comment Share on other sites More sharing options...
Paramanic Posted April 8, 2015 Share Posted April 8, 2015 i looked into this a while back only real way to get it and save loads is to make it ..... now making it wouldnt be too hard but is a wee bit more hassle but me personally not had time and with ma rifle just fitting in with the floor atm a thought to leave it :P Quote Link to comment Share on other sites More sharing options...
HarryNLD Posted April 8, 2015 Share Posted April 8, 2015 Not a problem. 1 Quote Link to comment Share on other sites More sharing options...
andywil13 Posted April 17, 2015 Share Posted April 17, 2015 Thanks all for your help So far so good :) I have been ordering the parts a bit at a time in case something doesn't fit and I don't waste too much money. These are the parts I have ordered so far and fitted: hinge right 1785935 £13.67 hinge left 1785936 £13.67 cover right 1805755 £11.05 cover left 1805756 £11.05 bolt x2 4364422 £4.58 (total not per bolt) back ledge 1822310 £23.10 I have just ordered the floor which is part number 1815967 costing a massive £91.70 so really hope this fits as its sort of the final part HarryNLD mentioned some other part numbers which are sort of optional I am hoping as with the bits I have ordered will give me basic functionality, and I may well add some other bits over time. Will post again when the floor gets fitted so fingers crossed. so far its cost me £168 which is just above my budget of £150 3 1 Quote Link to comment Share on other sites More sharing options...
jayteepics Posted April 17, 2015 Author Share Posted April 17, 2015 Andrew Thanks for the update on this I for one really hope you get a workable solution with what you have spent. Please keep us up to date on how this all pans out it's much appreciated! Jamie Quote Link to comment Share on other sites More sharing options...
StumpyBloke Posted April 18, 2015 Share Posted April 18, 2015 Thanks for the update Andy...am watching this with interest as I wouldn't mind adding this to my 2011. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
statts Posted June 28, 2017 Share Posted June 28, 2017 Hi New to the forum as i just bought a new titanium x fiesta 6 weeks ago. Just had adjustable load floor fitted at Pye Motors Morecambe and cost of supplied and fitted was £296.00. But did take 3 and 1/2 hours to fit. hope this is useful for people. Quote Link to comment Share on other sites More sharing options...
