Stolen St3
I had two keys with my lock but I do intend to get another cut for someone else who occasionally uses my car. thanks again
for your post about the lock and the advice about using sponge to protect the steering wheel.
No worries,, I tend to share good ideas with others. Keep us in the loop about finding somewhere to cut a spare key, as that will be good to know also.
  • Replies 128
  • Views 50.2k
  • The Dark Knight
    The Dark Knight
    That's it, all sorted. I might even paint a smiley face on the steering lock with a speech bubble that says "Better luck next time crims" Although, knowing my luck, I would just get a note through th
  • There will be no errors messages, if and when driving the vehicle with fuse 19 removed. With fuse 19 removed, there will be no power to the ODB port. Basically if you were to plug a device into the
  • Peterjones
    Peterjones
    Which would trigger the alarm as you have to be in the car to get access to the fuse box. Can't be done from the window and a real fiddle to do. I guess you could put a low blown fuse in the slot that
Does anyone know if there's been any issues with the st2 without keyless entry?
It's more to do with the keyless start.
Ah right ok, mine will have the keyless start but not keyless entry. I'll remove the obd fuse anyways just incase
