Mk7.5 Speaker Upgrade
And do anyone have diagram what speaker wires th st are coming from the radio
  • Replies 214
  • Views 58.1k
  • GingerFlame
    GingerFlame
    I would disconnect the battery & turn on the ignition the discharge everything, try to turn the radio on too. Then go make a cuppa, come back and unplug stuff You should be fine without but with a
  • Photo's will be good enough, but be sure to have as many as possible ^_^ (create a guide, that's "idiot" proof) :D
  • Any photos of this set up please? As me being a fan of Trance/Funky House... I do like some base. But dislike the rattling door cards! :D I used to have a JBL sub/amp installed in the boot of my pr
Right another daft question am gonna use piggy back to the fuse what one to connect it to?
Also shown in picture here I'm pointing at the fuse box and the yellow for noise cancel do I add that too the fuse box too if a noise appears?
Like both to fuse box
Not too sure, but no doubt someone can offer some guidance :D
Found you a wiring diagram... Haha!!
Well that's .........
Not helpfull :p
For power you should run it straight from the battery. This will reduce the possibility of noise/interferance. It will also ensure that your using big enough power cable throughout
For a signal for the sub you could just take it from the back of the radio whilst you're there. If it doesn't have a blue signal wire then Just use the ignition switched
On the manual is shows from fuse box buddy that'd why am doing that lol
How much power does the amp draw?...
Personally I'd go straight from the battery for peace of mind. As the "battery" feed is asking come straight from the fuse box but it Will want a permanant live too. So you could save a little time testing fuses and go straight from the battery. Also, you never know what size cable is in between the battery and the fuse you choose.. draw too much power and the loom needs a repair.. just the way I'd do it! :)
Let us know how it sounds too! Ice never used an active sub.. my whole ice system is powered on seperate amps
10amp........ the wire for it is only 14AWG lol
Ah fair enough then! Haha :)
a got this as not looking for massive bass but just enough to keep me happy lol
so as said before the power one (blue wire) going to fuse 13 (ignition a think) is this the remote wire ?
what fuse to use for the main power wire (piggy back) thats going to on all the time? the wire with 10amp fuse what would best to put this?
could someone confirm these thanks
and still looking for wiring of the plug that goes into the back of the head unit for the 4 wires front left and front right speakers
right found about the wires.............
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
now the other question and thats me fully confident
Where did you find out about the speaker wire colours? Just be sure they're correct before snipping.
a guy on facebook who put a subwoofer in about a month ago said and sounds about right he is Dutch but helped me in the past
he told me he got the info off this website but when he sees something he writes it down on a page in his pc so if he needs it for future lol
Are you going from the back of the head unit wiring into speakers ?
yeah mate make it neater but what im doing is snipping the wire then adding 2 bullet connectors and just connecting it to the subwoofer that way then when done i can remove the subwoofer (when selling car) and just plug the snipped wires together again and hey presto like a wasnt there :D
just found this too
http://www.fiestamk7.com/viewtopic.php?f=43&t=4855
James , this is the Topic i mean .
Put the info in TXT file. :)
Big help mate cheers
Wow, I feel like I've missed out on a lot here today! I'll have a more thorough read tomorrow morning; I hope everything is going well!
Morning mate yeah found out quite a but only thing now is looking for a constant feed from fuse box? That's only thing left to find out then ready to go :D.
Just waiting on wires through the post
Ummm, what about one of the 12V feeds? I think there is also a spare one of those that isn't in use, from memory. They provide power when the car isn't on, right? And blue remote wire to ignition to tell it to be on or off all makes sense to me :)
How does the subwoofer fit under the seat by the way, is it a nice fit?
Do you know where that is?
Yeah that's right and not checked yet but looks perfect and I'm still waiting on wires. Lol
Erm, not without having a look at the diagram again, but if you look at the diagram on the back of the glovebox, I believe there is a second 12V fuse that is actually not used. Or you could use the one that is already in use, I suppose!
