BugCo22 Posted April 3, 2015 Share Posted April 3, 2015 Had a rite mission this morning trying to change the flexi pipe on my car and it still not complete as I ran out of time. I also changed the oil first, that was done really quick as I had bought the tools for the job. The flexi however was a rite pain as all the nuts and bolts are/were seized. I started the cat end but got nowhere fast so moved to mid section. Ended up having to drop the whole exhaust down so I cud get sum leverage on the on the spanners. That bit come off easy enough at that point. Decided to attack the other end one last time, this time with a socket and hammer and manged to undo one of the nuts. I wasn't hitting it hard so shouldn't of damaged anything above :-/ then the misses !Removed! down an my time was up. Had to reassemble exhaust even though it's not attached to anything an call it a morning. Still there is jus one more nut to crack and then I can put in new flexi an that will be another tick in the box :-) Quote Link to comment Share on other sites More sharing options...
RyanMitcham Posted April 4, 2015 Share Posted April 4, 2015 Spray it up with loads of wd40 and let it soak overnight! Bit of heat generally helps as well! Quote Link to comment Share on other sites More sharing options...
BugCo22 Posted April 4, 2015 Author Share Posted April 4, 2015 I'll be finishing up 2moro so ill give it a gud spray this evening. When you say heat, as in driving toll hot or a torch ?? Quote Link to comment Share on other sites More sharing options...
RyanMitcham Posted April 4, 2015 Share Posted April 4, 2015 A blow torch! Heat up the nut which causes it to expand, will then come off much easier. Be very careful to make sure you have the correct size socket as obviously when the nut has been heated, it is softer and there is higher chance of rounding it! Quote Link to comment Share on other sites More sharing options...
BugCo22 Posted April 4, 2015 Author Share Posted April 4, 2015 Cheers for that, I'll see wot I can do lol. Quote Link to comment Share on other sites More sharing options...
BugCo22 Posted April 6, 2015 Author Share Posted April 6, 2015 Finally all sorted :-) I was quite surprised by the lack of gaskets though. Is that a sign of poor maintenence ?? Now I jus need a slightly louder exhaust lol. Also found my oil leak, it is the cam cover gasket. I'll do a bit of reading and get some bits and attack that when weather is good agen. Quote Link to comment Share on other sites More sharing options...
stef123 Posted April 6, 2015 Share Posted April 6, 2015 There should be a gasket where the flexi meets the middle section, it's like an O-ring but made of metal. And where the flexi meets the bottom of the cat there should also be an oval shaped gasket. Quote Link to comment Share on other sites More sharing options...
BugCo22 Posted April 6, 2015 Author Share Posted April 6, 2015 Yeah there wasn't either in there. However, both are in place now. Quote Link to comment Share on other sites More sharing options...
