jcs95whufc Posted April 12, 2015 Share Posted April 12, 2015 Hi guys, When I wash my wheels I notice lots of little black speckle marks, seem to me like tar marks from the road, however they just won't come off?? I've tried lighter fuel to rub it off, t-cut but I just can't remove them? Everyweek they get worse. Had any one got a similar problem but knows a solution to this? It's so annoying. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted April 12, 2015 Share Posted April 12, 2015 Easy way to remove is use either wd40 or a clay bar then apply a good polish Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted April 12, 2015 Share Posted April 12, 2015 As above & careful with the T cut - too much use & you'll cut through the protective lacquer. Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted April 12, 2015 Share Posted April 12, 2015 Some sort of wheel cleaner or tar remover, then as above you want to seal them with wheel sealant or wax so they're easier to clean next time. Quote Link to comment Share on other sites More sharing options...
StevenST13 Posted April 12, 2015 Share Posted April 12, 2015 The makes on your wheels are what is known as fallout and will also effect the body work of the car as well. What it actually is is red hot flakes of iron from you brake discs and other cars brake discs as well as industrial pollutants that are in the air. These bond to the body and wheels as the flakes are hots so in effect melt to the paint especially wheels as they get hot from driving. There are a few ways to remove them one which has been stated is the clay bar but there is an easier less time consuming approach which is a good fallout remover. So here's the steps to removing it. 1) clean the wheels as normal and dry them off (this lets the fallout remover get straight to the problem) 2) spray the fallout remover on to the wheel and let it dwell there for 2-5mins (a good one will turn purple as the chemical reaction takes place so you can see it working) 3) now apply a little more fallout remover and use a soft detailing brush to work it in and lift the fallout. 4) rinse well and reapply if it's necessary until it's all off. I've tried and tested these ones and they work very well. ValetPro Dragons Breath Angelwax revelation Iron X There are others but I do know these work. 2 Quote Link to comment Share on other sites More sharing options...
jcs95whufc Posted April 12, 2015 Author Share Posted April 12, 2015 Cheers guys that helps a lot! Will try this next weekend when I was again. It's such a pain lol Quote Link to comment Share on other sites More sharing options...
