hadyn Posted May 27, 2015 Share Posted May 27, 2015 my 06 diesel 1.4 fusion turn the i.key engine will not turn over and red light keeps flashing. light code is 11. has meter test and 3 codes show up po562,po685 and poa09.any help please.(tried spar key same thing) if it is the immobiliser unit where is it fitted in the car.thank you hadyn Quote Link to comment Share on other sites More sharing options...
Fused Posted May 28, 2015 Share Posted May 28, 2015 Check the battery and also the engine management immobiliser fuse. Quote Link to comment Share on other sites More sharing options...
hadyn Posted May 28, 2015 Author Share Posted May 28, 2015 thank you chris. battery meter tested and it is ok. is there a separate immobiliser fuse somewhere as all fuses in main fuse box pulled and tested ok .ps where is the immobiliser control box hidden so I can check the connections on it.hadyn Quote Link to comment Share on other sites More sharing options...
Fused Posted May 28, 2015 Share Posted May 28, 2015 The fuse has the engine immobiliser symbol on it. Suggest you put in "Immobiliser Light" into the search box at the top of the page and you will see more information Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 28, 2015 Share Posted May 28, 2015 The immobiliser fuse will be in the panel behind your glovebox. Quote Link to comment Share on other sites More sharing options...
ponsaloti Posted May 28, 2015 Share Posted May 28, 2015 Flashing code 11 is "Arial not connected". Maybe a fuse but usually arial around the ignition barrel has a problem. You can swap these between same models. Quote Link to comment Share on other sites More sharing options...
