grandads_shed Posted May 28, 2015 Share Posted May 28, 2015 hi over the past 2 weeks on 2 occasions i have had my dash give a engine malfunction message but it cleared on restart and never had a code, well today the engine light came on and i have a code "p0096 -- air intake temperature sensor 2 circuit range performance ""P0096 Intake air temperature (IAT) sensor 2 - circuit range/performance problem"" its reading air temp at 107.46F or about 42c which is much to high i think.. any advise about this ??/ where to sensor is and what could be the cause of the fault etc ,, any advise/info welcome it happened as i was excellerating to get onto a dual carrageway. also i noticed that the dash also said that i was only getting 36 miles to the gallon instead of the normal 50+ mpg its a 2010 mondeo tatanium 2.0L tdci desiel/ Quote Link to comment Share on other sites More sharing options...
BOF Posted May 28, 2015 Share Posted May 28, 2015 Often the problem is the wiring and not the sensor itself. Have a look for loose connectors, and shorts to ground, that sort of thing. 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted May 28, 2015 Share Posted May 28, 2015 Sensor is in the middle to right of engine, on the inlet manifold, theres 2 sensors close to each other. Its the one with connector at right angles to fixing bolt, other one is inline to bolt hole. 1 Quote Link to comment Share on other sites More sharing options...
grandads_shed Posted May 29, 2015 Author Share Posted May 29, 2015 Sensor is in the middle to right of engine, on the inlet manifold, theres 2 sensors close to each other. Its the one with connector at right angles to fixing bolt, other one is inline to bolt hole. Sensor is in the middle to right of engine, on the inlet manifold, theres 2 sensors close to each other. Its the one with connector at right angles to fixing bolt, other one is inline to bolt hole. i have found the MASS AIR FLOW SENSOR but can not find the Air Intake Temperature Sensorhere is a picture, Quote Link to comment Share on other sites More sharing options...
iantt Posted May 29, 2015 Share Posted May 29, 2015 havent got photo,its further to the left of photo 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted May 29, 2015 Share Posted May 29, 2015 found one on internet, may not be exact engine to yours but very simular, you will see 2 sensors at bottom of photo, its the one to the right. 1 Quote Link to comment Share on other sites More sharing options...
grandads_shed Posted May 31, 2015 Author Share Posted May 31, 2015 found one on internet, may not be exact engine to yours but very simular, you will see 2 sensors at bottom of photo, its the one to the right. thanks m8 , on mine the air pipes run from the front on the left and go round to the rear of the engine, i have had another look and i think they have put it round the back out of sight somewhere. i will get some more pictures asap. Quote Link to comment Share on other sites More sharing options...
iantt Posted June 2, 2015 Share Posted June 2, 2015 I have pm'd you about iat sensor. 1 Quote Link to comment Share on other sites More sharing options...
grandads_shed Posted June 2, 2015 Author Share Posted June 2, 2015 i think you may be right as i disconnected the plug from the maf andreconnected it, since then the codes have deleted and not come back, so it looks like it was just a dirty connector, and now i have a brand new spare iat that dont fit the car ... Quote Link to comment Share on other sites More sharing options...
Gr4h4m Posted August 11, 2020 Share Posted August 11, 2020 I have a 2010 Kuga 2.0 tdci. Will someone help me find the IAT sensor please? Quote Link to comment Share on other sites More sharing options...
Ryan3652 Posted August 26, 2022 Share Posted August 26, 2022 Hi I have this issue on my 2014 kuga p0096 and p0098-12 I've got intake air temp sensor 2 which indicates the one in the manifold. Well that's what you'd think haha , but unfortunately it hasn't cleared , has anyone had this issue ? Quote Link to comment Share on other sites More sharing options...
