Endless Reliability Issues
My 1.25 petrol car has 120,000 miles and is 9 years old so getting on a bit but in the 2 and 1/2 years I have owned it I have replaced....
From what I understand a lot of these are common issues
-Driver side door moulding.
-Driver side headlamp fitting.
-Thermostat housing.
-Ignition Coils and leads.
-Front suspension coild spring( did other side as precaution too).
-Front tyre due to fault ( admittedly not a ford issue)
Does this seem particlarly high for my car, I do mainly motorway miles and don't exactly thrash the thing.
I bough it with full FSH and do regular oil changes etc..
Maybe its time I bought something japanese, though it has been a great car for me otherwise.
For the number of miles I would say not entirely unexpected. I had a fuel pump go on my mk1.5 focus zetec ebony at 60k then 20k later a seal went on the replacement pump and it dumped a full tank of petrol on the road.
I think at around 80k it also had full set of discs and callipers replaced all round and rear suspension coils and bushings when i took it in for a belt change.
Ignition coil & leads are a common fault. As are the front springs.
So all you've really done out of the norm Is a door moulding (did this fall off?, if so; common issue) thermostat housing & headlight
Overall I'd say for 120k your cars done quite well.
When I bought my previous mk6 it had 120k and had a tonne of service history due to faults and damage :)
Ok, that's reassured me a little. I did a lot of the work myself so I've saved on labour in that way.
And yes the door moulding flew off on its own accord on a motorway.
The good think with ford parts it they're pretty cheap and available.
Belt was done before I bought it so if I can get another 20,000 miles from the car I'd be pretty pleased.
That's the thing with Ford's. So easy work on. The service history quickly stopped when I bought mine as I also did all the work, as I still do with this fiesta.. most recently a snapped spring :(.
The door trims are best stuck on with epoxy, silicone adhesive or 3m double sided tape :)
