Worst Case Senario Bonnet Wont Open
drummondjhn
well my focus mk2.5 1.8 zetec s got new pads and discs last week under my 3 month RAC warranty
couple of days later went to open bonnet and it wont tried all the guides to open ot wont budge key
just turns so its going back to garage tomorrow not sure yet if this is going to be covered under just
curious what you all think my worst case senario will be
cheers John
Should be the same set up as my Cmax was and my mate managed to unbolt the lock mechanism by reaching up under the car with a small ratchet.
Shoild be the same set up as my Cmax was and my mate managed to unbolt the lock mechanism by reaching up under the car with a small ratchet.
fingers crossed cheers foe reply
cost be about 80quid to get it fixed by ford, they replaced the lock cylinder. so expect that much as the maximum if its not covered by warranty.
Worst case is your key is worn and that has damaged your lock.
New grill
New lock assembly
New key.
Best case is worn key.
New blade
Good luck
Worst case is your key is worn and that has damaged you lock.
New grill
New lock assembly
New key.
New blade
Good luck
Dont forget the simple option of the connecting rod could have come away.
Garage going to do whatever needed on Wednesday to open then repair all under warranty so not to bad in the end hopefully
under warranty - you lucky sod!
New blade is cheaper than dis-assembling and re-assembling the unit.
Unless you fix it yourself free of charge!:)
dont think its the key tried the spare keys aswell
well now fixed the small white plastic part had snapped that was replaced but soon as any pressure
was put on nothing worked turned out the wire inside rubber had snapped all replaced under warranty
thanks for help everyone
quick question just something ive been wondering if a spring or shock was to need replaced on a zetec s is it same parts as
other focus models
cheers john
The ride height is a bit lower on the Zetec S as far as im aware so would suggest the springs to be different spec. Someone else will be able to give a definitive answer on that for you.
