jgriff Posted July 30, 2015 Share Posted July 30, 2015 Went to my car after work this evening and my boot won't open. At this point I should mention it's a 2008 mk2.5 zetec s. When i press the boot release button i can hear it trying to open but there's something preventing it from opening. Anyone any pointers on what i can do or try to get it open? Thanks in advance 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 30, 2015 Share Posted July 30, 2015 Have you got something jammed in the mechanism? 1 Quote Link to comment Share on other sites More sharing options...
jgriff Posted July 30, 2015 Author Share Posted July 30, 2015 Not that I know of. I just disconnected the battery and will try it in a few mins 2 Quote Link to comment Share on other sites More sharing options...
jgriff Posted July 30, 2015 Author Share Posted July 30, 2015 Reconnected battery and still no joy. Climbed into boot to see if anything was caught in mechanism but doesnt appear to be anything there 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 30, 2015 Share Posted July 30, 2015 Probably a weak or failed solenoid then. You may be able to remove the hatch trim and unbolt the lock from inside. 1 Quote Link to comment Share on other sites More sharing options...
jgriff Posted July 30, 2015 Author Share Posted July 30, 2015 Ok cheers mate, will have to try it over the weekend 2 Quote Link to comment Share on other sites More sharing options...
IINexusII Posted July 31, 2015 Share Posted July 31, 2015 does the boot open with the remote key? my boot switch failed due to water ingress but it worked fine with the remote fob. 1 Quote Link to comment Share on other sites More sharing options...
jgriff Posted July 31, 2015 Author Share Posted July 31, 2015 No wont open with remote or handle 😢 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 31, 2015 Share Posted July 31, 2015 Failed solenoid I reckon then. 1 Quote Link to comment Share on other sites More sharing options...
jgriff Posted July 31, 2015 Author Share Posted July 31, 2015 What does the solenoid look like or where is it located. Pulled the plastic cover from inside the boot to have a look 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted July 31, 2015 Share Posted July 31, 2015 It's integral to the whole lock mechanism. If it's failed then it's a new unit. 2 Quote Link to comment Share on other sites More sharing options...
jgriff Posted July 31, 2015 Author Share Posted July 31, 2015 How do i get it out though, is there screws holding it in and if they are undone will the boot open? I havent gotten the plastic trim fully off as its still fixed where the two screws are in the grab handles 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 1, 2015 Share Posted August 1, 2015 How do i get it out though, is there screws holding it in and if they are undone will the boot open? I havent gotten the plastic trim fully off as its still fixed where the two screws are in the grab handlesHi John, There are two Torx screws holding this panel in place, As you have said mate there inside the grab handles which only become exposed with boot open. Very bad design when it comes to this. I've got some images of whats inside i thought they may help you out somewhat having a visual of where everything is inside the panel. The two Torx screws grip in to plastic clipped grommets, Set inside bendable metal tabs inside the boot panel as saw in image below: The connection here links the boot latch to the handle on the outside of the boot door: Bridge white to black to bypass the outside button. If removing the outer boot handle; Need to remove six nuts from inside panel possibly enough room to reach in. The only bit of information i can add to this is: When i was changing my boot handle to one with camera i had to cut off the factory loom plug and crimp on connections: In the process of doing this; I forgot to disconnect the battery, When i had the cables stripped the touched each other making electrical contact. I noticed the noise from the boot latch was much louder maybe a stronger shot when these connections were bridged. Perhaps if you can unplug the boot handle loom and bridge white to yellow it will provide a stronger pop to lift the latch i dunno mate maybe worth a try. If it works then its your outer handle needs replacing, I've got one of those i can provide for free if you need it. The contacts in the outer latch can wear out but generally happens in wetter times in winter. All said mate, If it was my focus id try bridging white&black connection while pushing boot, Failing that as much as i wouldn't want to; Id get a dremil tool and cut around the edge of the plastic boot panel leaving the plastic frame intact while allowing full access, Only way to gain full access without damaging the metal tabs on the boot door itself. If cutting it id keep bottle of water to hand aswell encase the backing insulation gets hot. Boot panel shouldn't cost that much in breakers maybe 20-30 euro I don't know what else to suggest to be honest. Hopefully images will help in some way and if you want the replacement button PM me details ill ship it out Tuesday. Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 1, 2015 Share Posted August 1, 2015 Hang on a second, I went back through archive of images to when i done the second boot light install, Notice theres two grommets on the lower boot panel: If you pop these out using a flat head screwdriver, They should reveal Torx head bolts which retain the lower boot latch bar. Granted the lower latch wont come up completely when you remove the two torx bolts, The boot will lift up about one or two inches, But if you then remove these two plastic plugs loosen then by prying with flat head screwdriver then pull panel to remove completly: That panel unclips by gently pulling it towards the back seat and upwards in the air. This should then allow the boot to fully open. You can then remove panels and check the outer boot handle. The above images were taken from the following Guides: De-Wiper Focus Mk2 & Mk2.5: http://www.fordownersclub.com/forums/topic/70383-guide-de-wiper-ford-focus-mk2-mk25-rear-wiper-removal/ Additional Boot light install: http://www.fordownersclub.com/forums/topic/27165-guide-to-fitting-additional-boot-light-in-ford-focus-mk2-and-mk25/page__pid__146083#entry146083 Focus Mk2.5 Reverse Camera Install: http://www.fordownersclub.com/forums/topic/65470-guide-fitting-reverse-camera-mk25-focus-2008-2011/ 1 Quote Link to comment Share on other sites More sharing options...
jgriff Posted August 1, 2015 Author Share Posted August 1, 2015 You're a fountain of knowledge lenny, fair play to ya. At least i have a couple of ways to try get it open now and know how to go about it. Typical of this happening and neal egan show in sligo on tomorrow. Will try a scrappy today to see if i can get the few bits required Cheers 2 Quote Link to comment Share on other sites More sharing options...
jgriff Posted August 2, 2015 Author Share Posted August 2, 2015 Just to update, i have the lock problem sorted. As you suggested it was the lock mechanism that had failed. A visit to my local scrappy and a lock from a 2007 focus and we're back in action. Only thing that remains to be done is to cut the old lock apart so that I can get the lower boot plastic trim piece fitted back to the car. 2 Quote Link to comment Share on other sites More sharing options...
