sonstar Posted August 1, 2015 Share Posted August 1, 2015 hi im new to this but id like to buy some ford fiesta zetec fog lights and install them on mine the only problem is i don't know if there should be wiring for them behind the bumper as mine come without the fog lights but my car has the switch and light on the dash hope this makes sense how do i know if i got wiring for them still and how easy is it to do to put them in thank you Quote Link to comment Share on other sites More sharing options...
BobbyDee Posted August 1, 2015 Share Posted August 1, 2015 I get what you mean with the switch, It has the setting for both front and the rear fog. The easiest way to check if you already have plugs is to remove one of your headlight and have a look for the wiring it might be tied up to something else or just hanging loose I would also check to see if there is a bit on the bumper to mount the fog light. Quote Link to comment Share on other sites More sharing options...
sonstar Posted August 2, 2015 Author Share Posted August 2, 2015 hi mate thanks for your reply big help this is what i found is this the connecter for the fog and is these holes to mount the fog thank you Quote Link to comment Share on other sites More sharing options...
BobbyDee Posted August 2, 2015 Share Posted August 2, 2015 Yeah thats exactly what you are looking for mate, All you need now is the fog light, the screws to mount them, the trim surround and of course bulbs. To mount the fog light can be a little annoying I would start with the drivers side as it easiest to do. You pretty much slide the fog unit into place until you can feel its solid then put the screw in , you can have your new trim in for this part as I won't get in the way. Also with the passenger side you will probably have to remove your horn so that you can slide the unit down. You could always coming in from the wheel wells to install them but I've always just removed the headlights as I feel its easier. 1 Quote Link to comment Share on other sites More sharing options...
sonstar Posted August 2, 2015 Author Share Posted August 2, 2015 thanks mate just one more question what screws will i need thanks Quote Link to comment Share on other sites More sharing options...
sonstar Posted August 2, 2015 Author Share Posted August 2, 2015 are these the ones i need mate im sure they are but just to double check Quote Link to comment Share on other sites More sharing options...
BobbyDee Posted August 2, 2015 Share Posted August 2, 2015 Not sure about the screws, never had to replace mine although I'm sure you would be able to get some from ford. Also they are the correct fog lights and trim and they take a H11 bulb. Quote Link to comment Share on other sites More sharing options...
sonstar Posted August 2, 2015 Author Share Posted August 2, 2015 and do my old surrounding trim unclip how do i get them out mate Quote Link to comment Share on other sites More sharing options...
BobbyDee Posted August 2, 2015 Share Posted August 2, 2015 Just unclip them, I would recommend either a flat head screwdriver with a cloth over it to protect your paint or get some plastic removal tools handy for lots of other jobs aswell. Quote Link to comment Share on other sites More sharing options...
sonstar Posted August 2, 2015 Author Share Posted August 2, 2015 ok thanks for your help mate 1 Quote Link to comment Share on other sites More sharing options...
sonstar Posted August 2, 2015 Author Share Posted August 2, 2015 just noticed the bumper is for a fiesta that doesn't have fog lights as the trim is part of the bumper but im going to buy a bumper complete with fog light but do u know how easy it be to do Quote Link to comment Share on other sites More sharing options...
sonstar Posted August 28, 2015 Author Share Posted August 28, 2015 Hi mate do u know what size clips I need for the wheel arch and bolts for the front bumper Quote Link to comment Share on other sites More sharing options...
