TonyRotchford Posted August 11, 2015 Share Posted August 11, 2015 Good Morning Folks, I have a ford focus MK1 1.6 Zetec petrol and have been having some problems lately. I am wondering if anyone has encountered the same problems and if they could advise me on what they could be caused by, they are as follows: 1. The car fails to start, it starts but cuts out straight away like petrol isn't getting through. The car then won't start again for maybe 1-2 hours and sometimes I have had to leave it overnight, I have had it at my local garage and they have had it on a diagnostic machine to tell me that they can't find anything, any ideas? 2. Whilst driving I have changed gear and put my foot on the accelartor only for it to rev up and act sluggish, the best way to describe it is that it's as if it's changed to an automatic with delayed burst of accelration. Can anyone suggest any help or advice on these two problems? Can they be interlinked? Kind Regards Tony Quote Link to comment Share on other sites More sharing options...
iantt Posted August 11, 2015 Share Posted August 11, 2015 Fails to start, fuel pump in tank quite common to play up as you describe, so next time you have it fail to start, just switch ign on and listen for pump priming for a few seconds before it stops , or while its running ok, do the same so you know what your listening for. Quote Link to comment Share on other sites More sharing options...
TonyRotchford Posted August 13, 2015 Author Share Posted August 13, 2015 Thanks Ian mate I will look into getting that changed. Do you think this could be the reason for the acceleration issue as I had seen on other forums this could be a throttle sensor. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted September 1, 2015 Share Posted September 1, 2015 could be the TPS, but could be the crankshaft sensor as well, which may tie in with the starting issue. Quote Link to comment Share on other sites More sharing options...
TonyRotchford Posted September 23, 2015 Author Share Posted September 23, 2015 Thanks to everyone for their advice, I had the Cranshaft sensor replaced and it seems to have sorted the starting problems, however the car now is idling really low and almost cuts out when starting. Really frustrating!! 1 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted September 23, 2015 Share Posted September 23, 2015 That could be the air filter or the idle control Sent from my GT-I9195 using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
