Leaking Fluid Into Driver Footwell
mastersmithson
Hi all!
Have a weird issue with my focus.... there seems to be a leak coming down the clutch pedal and into the foot well. Not a massive one but it's there! Looks like from the cylinder.
I recently had a massive power steering fluid leak and that's just been fixed. When the leak started, weeks and weeks ago, I marked all the 'bottles' in the bonnet where the liquid was. None of them have moved except for the power steering fluid, as mentioned.
I known issue I have is the seals gone on the bottom of the windscreen so rain could get in.
Any ideas?
Is the fluid water or is it sticky/greasy/coloured?
The type of liquid it is should point you in the right direction.
Clutch fluid should feel slippery/oily.
I would say most likely a master cylinder leak?
It does sit above the pedal.
  • Like 2
I had the same it was the master cylinder leaking
clutch fluid
Clear type oil.
Weird thing is that the levels in the monet is not going down. At all. It's been happening for about 2 months. No drop in level.
I had this problem and it turned out to be my heater matrix - nightmare job.
Clutch fluid then
It can only be brake/clutch fluid.
Master cylinders on the mk1 are famous for leaking.
So the fluid in the bonnet is not going down still......however..... the window washer liquid is going down.
Could it be possible that somehow, these two are liked?
They should not be linked - totally separate reservoirs
think the fluid washer bottle is on the other side of car so cant be that have a look around
the heater matrix for leaks
  • 4 weeks later...
  • 2 months later...
So last couple of days I've Had A Small Puddle on the car matt. The liquid is clear and only very slightly oily. Not sticky. Looks like it is still coming out the cylinder but the bottle in bonnet hasn't really gone down. ... thoughts?
Also is it an MOT failure and how easy is it to change yourself
Fiddle job but can be done without removing the steering column I've done a few but like
I said its fiddle
Oh sorry I didn't see that post!
I've got no experience at all... my knowledge with cars are minimal...... can I do it from YouTube video? Unless someone lives around dorset here!!!
It's pretty straight forward, I can swap one over in around 20 mins and then another 5-10 mins to bleed it.
You'll need a set of spanner a, preferably ratchet as the bolts holding the master cylinder on take a while to unscrew otherwise.
