Karol Wilk Posted August 25, 2015 Share Posted August 25, 2015 Hi guys, im an owner of a brand new zetec s, i have changed the footwell bulbs to really nice blue ones and really like the way they look, what i want to ask you is if you can change the bulbs in both front and back ceiling lights, and if so how would you go about it and would they be the same bulbs that i used for the footwell lights? many thanks! Quote Link to comment Share on other sites More sharing options...
matt1981 Posted August 25, 2015 Share Posted August 25, 2015 Yes they are the same bulbs and easy to do, I've changed mine to red ones to match my footwells. You will probably need a flat knife or similar, there are clips at the front and back of each of the lights and then the housing just drops down (it shows you in the manual). There are 3 bulbs in the front one. Just change the centre bulb to blue then you will keep the other 2 map reading lights white which can be handy if you ever need them Quote Link to comment Share on other sites More sharing options...
CookieM Posted August 26, 2015 Share Posted August 26, 2015 Isn't the front centre light a festoon bulb with two W5W map lights? that's what I had in my ST, might be different in the ZS though... Quote Link to comment Share on other sites More sharing options...
Dave754 Posted August 26, 2015 Share Posted August 26, 2015 Yes front centre light is a festoon with 2 x W5W for the map lights with a single W5W in the rear ceiling light. I've put white LED's in the roof lights with red LED's for the footwell bulbs to match the existing mood lighting. Quote Link to comment Share on other sites More sharing options...
Willy Posted August 27, 2015 Share Posted August 27, 2015 Festoon bulb on the ST and w5w / 501 on the other Fiesta's Quote Link to comment Share on other sites More sharing options...
