focushassle Posted August 27, 2015 Share Posted August 27, 2015 Six months after the old girl passed her MOT predictably it's knocking again(sigh) When driving there is knocking coming from all over the car, and it's mainly under my feet or centre console, really bad esp when going over rough road and speed bumps. The smaller the bumps worse the knocking is. So when it was parked up and engine off I tried rocking the steering gently side to side. every time I change direction there is a loud 'knock' and it sounds like it's coming from where the rack is. Things i've replaced over the last 6 months are; New O/S drive shaft Both wishbones, drop links and tie rod/ track rod ends , I have double checked and there is no play in any of the new items. Has any one else had this sort of issue? I'm thinking either steering rack or steering arms.. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted August 28, 2015 Share Posted August 28, 2015 Strut top mount would be my first culprit you wont get much side to side movement but up and down it will bang like a brothel headboard that will transfer through the driveshaft making it sound like its somewhere else easy test jack up or park the side that isn't doing it up on a kerb putting load on the culprit side push on the body and listen to the strut mount for noise other than that IDE look at the gearbox mount 1 Quote Link to comment Share on other sites More sharing options...
focushassle Posted September 9, 2015 Author Share Posted September 9, 2015 Strut top mount would be my first culprit you wont get much side to side movement but up and down it will bang like a brothel headboard that will transfer through the driveshaft making it sound like its somewhere else easy test jack up or park the side that isn't doing it up on a kerb putting load on the culprit side push on the body and listen to the strut mount for noise other than that IDE look at the gearbox mount Spot on dude, I replaced the drivers side strut top mount and the knock has gone:) Cheers for the heads up. Just got to find the knock at the back now .... Quote Link to comment Share on other sites More sharing options...
artscot79 Posted September 9, 2015 Share Posted September 9, 2015 glad its sorted dealer tried to charge me for two driveshafts plus oil seal plus fitting £687.39 inc vat take a guess where i told them to put that one all in the mount and bearing was about £54 replaced the drop link as well for £12 while i was at it Quote Link to comment Share on other sites More sharing options...
