Davetiler Posted August 31, 2015 Share Posted August 31, 2015 Drove to a friends house,about 1 hour,as soon as I started the return journey I developed a knocking on the front or so it seems,I can feel it through the steering All new shockers and ball joints on the front Any ideas please,just jacked it up on the front can't find anything Dave Quote Link to comment Share on other sites More sharing options...
pragmatix Posted August 31, 2015 Share Posted August 31, 2015 Possible drop links Quote Link to comment Share on other sites More sharing options...
Goodkat Posted August 31, 2015 Share Posted August 31, 2015 Engine mount? Brake pad slipped from calliper? Bearing? Sent via the 'Clacks' GNU STP Quote Link to comment Share on other sites More sharing options...
Davetiler Posted August 31, 2015 Author Share Posted August 31, 2015 Rocked the engine appears solid Checked calipers Rocked the wheels re bearings appear solid Quote Link to comment Share on other sites More sharing options...
Davetiler Posted August 31, 2015 Author Share Posted August 31, 2015 New drop links both sides Quote Link to comment Share on other sites More sharing options...
Goodkat Posted August 31, 2015 Share Posted August 31, 2015 CV joint? Sent via the 'Clacks' GNU STP Quote Link to comment Share on other sites More sharing options...
pragmatix Posted August 31, 2015 Share Posted August 31, 2015 Road speed or engine speed or only over bumps? Quote Link to comment Share on other sites More sharing options...
Goodkat Posted August 31, 2015 Share Posted August 31, 2015 Stupid thought, but are all the wheel nuts tight? You'd be surprised how often that is dismissed due to it being a silly suggestion. Sent via the 'Clacks' GNU STP Quote Link to comment Share on other sites More sharing options...
Davetiler Posted September 1, 2015 Author Share Posted September 1, 2015 Hi yes had both wheels off,to look for any problems Seems to be worse on bumpy roads To check cv joint ,I will try running in a circle ,should be able to hear it cracking ,if it is the cv joint is it easier to change the whole shaft Quote Link to comment Share on other sites More sharing options...
ppeter7 Posted September 1, 2015 Share Posted September 1, 2015 Seing as you have had replacement shocks,.Have you checked spring sitting correctly and not broken.Shock top mount not loose the 1 where the shock gose through the top bearing.Anti roll bar bushes or subframe bushes Quote Link to comment Share on other sites More sharing options...
StornowayBlue Posted September 1, 2015 Share Posted September 1, 2015 Seing as you have had replacement shocks,.Have you checked spring sitting correctly and not broken.Shock top mount not loose the 1 where the shock gose through the top bearing.Anti roll bar bushes or subframe bushes Good shout I reckon, I had similar symptoms on my Fiesta mk7, turned out to be top mount. Springs been done twice this year alone so it just wasn't put back properly. Quote Link to comment Share on other sites More sharing options...
Davetiler Posted September 2, 2015 Author Share Posted September 2, 2015 Shocks ok Will check anti roll tonight Quote Link to comment Share on other sites More sharing options...
