ukd4v1d Posted September 12, 2015 Share Posted September 12, 2015 But because I'm good I've managed to alter my loom and it's now working ;) 1 Quote Link to comment Share on other sites More sharing options...
ukd4v1d Posted September 13, 2015 Share Posted September 13, 2015 I've only got mono sound naturally because I don't have another wire in my by/vc plug, so at the stereo end I've just bridged it so sound comes from both sides. It works spot on, as all I'm using it for is phone capability since my unit does not have USB, and people want silly money for the USB version Quote Link to comment Share on other sites More sharing options...
ukd4v1d Posted September 13, 2015 Share Posted September 13, 2015 Chw1 if you are in same boat and do not have usb. bt/vc plug end move pin 1 white wire to either 5/6 (6 is left 5 is right) and move pin 2 brown wire to pin 23 Stereo end remove brown and white from pins 1&7 of the b connector which is black on my loom Move the brown wire from pin 7 from b connector ( the black one) to c connector (the white one) pin 6 which is occupied by a black wire (from your aux port) , move the White wire from pin 1 of your b connector to either of the 2 white occupied wires in c connector pins 5&11 bridge the two to hear the sound through both sides If you have done it as I have done it, this will render your aux port useless but only through your patch cable (which is the one you are changing) if you put your car back to stock aux port will again function as the wires are all right in the cars loom. You can wire it to work with both but you would require some more pins for the bt/vc plug and some wire as you don't have enough wires to move as old mono loom has 10 wires whereas stereo loom has 14 wires You could also bridge the wires at the stereo end on the c connector to leave your aux plug working but because you have only got either the left or right sound due to lack of wires your vc and phone sound will only come out one side Quote Link to comment Share on other sites More sharing options...
ukd4v1d Posted September 13, 2015 Share Posted September 13, 2015 If I can find a supplier of the pins required for the bt/vc connector I'm going to modify it to make it into a stereo loom just in case I source a newer bt unit with usb at a later date I did the same with my mic wire I removed the pins from mic connector of my patch loom and installed them into the plug in the passenger a pillar (as my titanium has the mic wire from the a pillar to the light but it stopped at the a pillar) this enabled me to use oem mic in the light Quote Link to comment Share on other sites More sharing options...
tomsteetley Posted May 31, 2017 Share Posted May 31, 2017 Hello, Do you know if the following module will work in a 2010 focus titanium mk2.5 8M5T-19G488-AK Quote Link to comment Share on other sites More sharing options...
JW1982 Posted May 31, 2017 Share Posted May 31, 2017 2 hours ago, tomsteetley said: Hello, Do you know if the following module will work in a 2010 focus titanium mk2.5 8M5T-19G488-AK Yes, this type of module will work fine. However be aware that this part number is a normal Bluetooth/Voicecontrol module which only supports basic bluetooth phone functionality. This type of module does not support USB, bluetooth Audio or Ipod control. Quote Link to comment Share on other sites More sharing options...
Snesy Posted December 30, 2017 Share Posted December 30, 2017 Hi, dunno if this thread is still active but I’m after a little advice if possible, are these devices compatible? I have recently upgraded my radio from a standard gen2 Sony unit to the DAB version (gen3 I believe??) I’ve removed the glove box and located the connector for the bt module and connected it up, my phone pairs with the radio and everything works except there is no audio. Car: 2007 Focus Titanium (mk2) Radio: 8m5t-18c939-LE bluetooth module: 8m5t-19g488-AM am I right In presuming that I have the old style wire looms (mono)? But now have the newer type devices? Would the Retrofit (Finis 1667645) fix the audio problem I’m having? Or is there a different way? any help/advice would be great Quote Link to comment Share on other sites More sharing options...
Jacob Tracey Posted September 21, 2021 Share Posted September 21, 2021 Got a similar problem that I could use help with. I have a mk2.5 focus 11/08, and I have fitted the Sony dab radio (including new antenna and look up a pillar), this has voice control and allows me to answer calls. I would like to access the function to play music from my phone. As far as I’m aware, I need to change the module in the glovebox, correct? is it as simple as replacing this with a module 8M5T-19C112-AR, for example, and then it works straight away? Or do I need to add usb components/ looms ect? my current module is 7M5T-19G488-AE any help would be truly appreciated. Thanks in advance, Jacob Quote Link to comment Share on other sites More sharing options...
