mondeo fault code p2263
jdw66
Any ideas what this points to ? all i know is it is turbo boost system performance,Turbo? car is now in limp mode i have a obd reader this is how i got the code but i dont want to erase it so i can show mechanic if need be.Thanks
the two common faults for this code is the egr valve is stuck open. you can remove and clean this -http://fordwiki.co.uk/index.php/Main_Page ( check out the egr valve clean under the mondeo section)
or the electronic turbo actuator return arm is siezed due to a build up of carbon on the turbo vanes, you can check this by seeing if you can move the little arm by hand when you remove the clip on the arm. but this is unlikely unless you have mega miles on the car. i would try the egr first.
I had the egr and inlet manifold off a few weeks ago and gave them a good cleaning still had juddering and seemed to still be smoking,do you think it could be split in boost pipe from egr to intercooler?. Only 72k with full service history how easy is it to look actuater arm?.Could i have a faulty egr valve?
juddering at around 1800rpm and black smoke are symptons of a split intercooler pipe.
Your were spot on mate intercooler pipe had a 3 inch split relaced it still smoking but no judders hopefully it will clear after a good run out.Thanks again all !!!!!
  • 4 years later...
Hi there,
I have a problem with the car going into limp mode, and the engine management light coming on (occasionally). The code reader shows 2263 (turbo boost issue).
I have replaced the stainless steel pipe to the EGR valve, had the valve cleaned out and I have now blanked it off.
I start the car in the mornings, and the car runs perfect, no juddering, loss of power, or anything. I stop the car for less than 2 hours and I get the dreaded limp mode. If I leave the car for more than around 3 hours, now problem on starting and driving.
I have read on posts that a turbo hose could be leaking, although I can't see that as I have no loss of power at all.
I have read that the MAS sensor could need cleaning.
I have also seen that there is a vacuum thing between the MAS and the EGR valve, I assume it is a boost sensor valve as it has three pipes going into it. between the EGR valve, the turbo actuator and some where else?
Can anyone give me any tips on how to resolve this problem, very frustrating as I thought I had cured this by blanking off the EGR valve. The car ran perfectly for 4 days without limp mode, which made me think it was all sorted?
Thanks in advance for your help xxxx
You wont feel a massive drop in performance on the car if you have a split pipe or hose. I would be starting the engine and getting someone to give it a few revs whilst feeling around the intercooler pipe for any leaking air.
  • 1 month later...
Hi I had the same problem lots of juddering and hesitation also fault code p2263 my turbo pipe had split the 90 degree bend one I've changed that I also blanked the egr valve off as well massive improvement now I'm getting a whistle when the turbo is spoiling up and down no loss of power at all but I don't notice smoke through the day but a hell of a lot at night even when turbo hasn't kicked in any surgeations
I also found a slit in the rubber intercooler/egr valve hose. Was a horrible hub trying to fit the bottom of the hose onto the intercooler pipe, but got there in the end. Car runs really well now, but also smokes a bit when I give it some revs through the gears. Not really bothered me too much though as I'm just glad I finally got to the bottom of this ongoing problem. I reckon it is worth while giving it a good Grady from time to time, as this seems to give the turbo vanes a good dechoke.too much town driving causes these problems with the vanes. Even long journeys I don't think clear the vanes properly. A ggood frash I would say works.
Smoking could be egr to be honest did you replace the egr valve hose?
The egr vacuum hose I believe is separate to the egr pipe your referring to if I'm not mistake
  • 6 years later...
Had the p2263 on my 2008 mondeo tdci looked on many forums at the fault mine turned out to be the mas sensor simple fix and only 30 quid car running alot better and mpg has gone up to a respectful figure.
