MONDEO TXS 2.2 Posted December 7, 2015 Share Posted December 7, 2015 The outcome & cause will be of benefit for the future . . . Keep us posted :) 1 Quote Link to comment Share on other sites More sharing options...
Ash666 Posted December 7, 2015 Author Share Posted December 7, 2015 Yeah I sure will do so might help others 1 Quote Link to comment Share on other sites More sharing options...
RSpilla Posted July 19, 2016 Share Posted July 19, 2016 Did you find the problem Ash, I have all the symptoms you had, bulbs work, bulbs work in holders at another 12v source, 10-11v going to reverse light connector when selecting reverse. Still no lit bulb, but i also have the issue of the parking sensors working when the bulb is removed but are dead with the bulb fitted. Have also spliced the ground wire going to the reverse light connector and grounded it to the chassis, still nothing. Can anybody shed any light on this? Thanks. Quote Link to comment Share on other sites More sharing options...
Tdci-Peter Posted July 20, 2016 Share Posted July 20, 2016 13 hours ago, RSpilla said: 10-11v going to reverse light connector when selecting reverse. Still no lit bulb, but i also have the issue of the parking sensors working when the bulb is removed but are dead with the bulb fitted. Sounds like a bad contact in the gearbox reverse switch. Like It has high resistance, but reads on a meter (a bit low), or enough to trigger the park aid, but not well enough to operate a bulb. 1 Quote Link to comment Share on other sites More sharing options...
RSpilla Posted August 2, 2016 Share Posted August 2, 2016 On 20/07/2016 at 2:26 AM, Tdci-Peter said: Sounds like a bad contact in the gearbox reverse switch. Like It has high resistance, but reads on a meter (a bit low), or enough to trigger the park aid, but not well enough to operate a bulb. Found somebody had cut the reverse light wiring where it meets the o2 sensor loom and the connectors they used to join them up had corroded. All fixed now. Light and sensor working great. Thanks for the help. Nick. 1 Quote Link to comment Share on other sites More sharing options...
