lufc08 Posted December 31, 2015 Share Posted December 31, 2015 I recently decided to change the head unit in my MK6.5, it's never been done before so everything is stock. I have bought a Pioneer AVH-3600DAB and a fitting kit, This one to be exact, http://www.ebay.co.uk/itm/380973884154?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT I managed to remove the old 6000cd but now I'm stuck. The new fascia adapter with the kit doesn't fit the space left by the old stereo, it's slightlty too thick so it sticks out a bit. Also I assume the new unit screws into the cage but i can't see where it would. I'm probably missing something really simple but I just can't seem to find what it is. Hopefully someone can help me out (make me feel a little stupid) and tell me what I'm doing wrong. Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted December 31, 2015 Share Posted December 31, 2015 First of all, the headunit does not screw into the cage. that's just an option for some cars if needed. It clips in place. Fit the cage, bend the prongs to hold it in place. Slide in the radio and "click" Which bit of the fascia is not fitting? Could you post some pictures please? Quote Link to comment Share on other sites More sharing options...
lufc08 Posted December 31, 2015 Author Share Posted December 31, 2015 I'll post some pics tomorrow when I have another look at it. Thanks for the help. 1 Quote Link to comment Share on other sites More sharing options...
lufc08 Posted January 1, 2016 Author Share Posted January 1, 2016 I've had another look, I put the fascia plate in first which still doesn't fit quite right, I can get one side in fine but not the other. I put the cage into it then the radio, Which clips bend to secure the radio in place? I also have some brackets but I'm not sure where I'm supposed to use them. I've attached some pics to show what I mean. 1 Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 1, 2016 Share Posted January 1, 2016 Could you post some pictures of the cage? www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
lufc08 Posted January 1, 2016 Author Share Posted January 1, 2016 Sure thing. 1 Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 1, 2016 Share Posted January 1, 2016 If you slide the radio into the cage outside of the car does it click into place? Also, see the triangular tabs? When you get the cage in place in the car, bend as many of them as far as possible to lock the cage in place :) As silly as it sounds, have you tried rotating the fascia by 180*? Quote Link to comment Share on other sites More sharing options...
lufc08 Posted January 1, 2016 Author Share Posted January 1, 2016 No it doesn't, in fact it slides right through it. That's why I thought it needed securing in place. Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 1, 2016 Share Posted January 1, 2016 That's extremely unusual.. didn't the radio come with a cage in the box? My AVH2600BT came with a cage.. www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
lufc08 Posted January 1, 2016 Author Share Posted January 1, 2016 You're right it did, hadn't even considered that. It clicks in place with that cage fine. Now my only problem is the fascia not fitting into the car properly. Any ideas on that? Thanks for this, big help. 1 Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 1, 2016 Share Posted January 1, 2016 Try rotating it through 180* www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 1, 2016 Share Posted January 1, 2016 If not, some fine grade sandpaper to reduce the size slightly www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 1, 2016 Share Posted January 1, 2016 Could you post some pictures of the area that the fascia clips into without the fascia in place? www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
lufc08 Posted January 1, 2016 Author Share Posted January 1, 2016 I tried to rotate it but got the same problem. Not sure whether the fascia has been cut wrong. I think before sanding it down I may ask the seller to send a replacement fascia and try it that way, if the same thing happens then I guess sanding will be the way forward. 1 Quote Link to comment Share on other sites More sharing options...
lufc08 Posted January 1, 2016 Author Share Posted January 1, 2016 I think I may be onto something here, I think its the block on the bottom that's stopping it going in far enough. It's the bit in the middle of the second picture, think it's ok to get rid of? Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 1, 2016 Share Posted January 1, 2016 Yeah its just a guide for the factory radio but even if you refitted it, pad some foam at the bottom and it would be fine. Cut it out :) www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
lufc08 Posted January 1, 2016 Author Share Posted January 1, 2016 Don't think I'll have a chance to do it today but I reckon that'll be it. One last thing, what's the best way to go about getting a dab aerial setup? I think I have one knocking around that I was given but it's a roof mounted one, is the cable easy to route? Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 1, 2016 Share Posted January 1, 2016 I didn't know your radio supported DAB if I'm honest www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
lufc08 Posted January 1, 2016 Author Share Posted January 1, 2016 Yeah it's this one http://www.amazon.co.uk/Pioneer-AVH-X3600DAB-Touchscreen-Integrated-MirrorLink-Black/dp/B00G5AW2RS Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 1, 2016 Share Posted January 1, 2016 Ah its one of the newer models thats why :) www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
