timbo50 Posted December 31, 2015 Share Posted December 31, 2015 Can anyone help please? 2012 Focus quite suddenly doesn't recognise any USB stick and shows 'line-in active'. Tested USB sticks in other devices and OK. Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted December 31, 2015 Share Posted December 31, 2015 Press your AUX button on your radio? 1 Quote Link to comment Share on other sites More sharing options...
timbo50 Posted January 1, 2016 Author Share Posted January 1, 2016 Thanks for your answer. I've pressed everything including the usual 'aux' button, but the display shows 'line in activated'. Bear in mind this has been working normally for two years. Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 2, 2016 Share Posted January 2, 2016 Cant you switch wether the radio activates either USB or line in in the radio settings? Try holding aux? Quote Link to comment Share on other sites More sharing options...
timbo50 Posted January 3, 2016 Author Share Posted January 3, 2016 Thanks for looking. When the 'line in activated' message shows, the alternative is 'BT line in'. Both showing on the AUX item on the menu. Quote Link to comment Share on other sites More sharing options...
iantt Posted January 3, 2016 Share Posted January 3, 2016 i would disconnect battery for 5 mins and see if the bluetooth module resets. i had issues with my sync module not regognising usb at all. sync reset in settings didnt work so disconnected battery for 5mins and it worked again. 1 Quote Link to comment Share on other sites More sharing options...
timbo50 Posted January 3, 2016 Author Share Posted January 3, 2016 Many thanks. I'll give it a try. Quote Link to comment Share on other sites More sharing options...
