Pottsygsxr Posted January 2, 2016 Share Posted January 2, 2016 Hi. I have 53 plate 1.4 focus. When you turn on the ignition and hold the trip reset button it tests the clocks etc... Does it also give you fault codes it has what looks like 969E on it but the 6 is back to front... Nit sure if that a fault code or not? Thanks Quote Link to comment Share on other sites More sharing options...
WES180 Posted January 2, 2016 Share Posted January 2, 2016 I dont think yours has that feature although i could be mistaken. Whats wrong with your car or are you just curious? Quote Link to comment Share on other sites More sharing options...
artscot79 Posted January 4, 2016 Share Posted January 4, 2016 The mk1 still shows the codes nut that's not a dtc its the rom level of the software as you go through you get dtc then if there's a fault 01 so dtc 01 the a code below Quote Link to comment Share on other sites More sharing options...
