BrianM Posted January 3, 2016 Share Posted January 3, 2016 I've had some electrical problems (think the wiper relay is screwed) and had the fuse board in and out. But it was working fine last time I locked the car, except the wiper issue. Anyway the car was beeped shut and now it refuses to open, the car and fob battery is definitely fine. Unfortunatly the drivers door lock also appears to be seized leaving me without access. Any suggestions other than a brick? Quote Link to comment Share on other sites More sharing options...
williamweb Posted January 3, 2016 Share Posted January 3, 2016 Have you tried disconnecting the battery so the car resets it's self.Just a thought. Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
dezwez Posted January 4, 2016 Share Posted January 4, 2016 do you have breakdown cover if so call them out they should be able to open it Quote Link to comment Share on other sites More sharing options...
