JordFocus Posted January 12, 2016 Share Posted January 12, 2016 Alright lads/lady's, Got a fault with my mk2.5, When I use the electric mirror adjust button on the drivers door, the offside rear indicator comes on? Absolutely baffled! I should mention it's only when I press the bottom and left directions, and it happens when both mirrors are being adjusted! Thanks in advance! Quote Link to comment Share on other sites More sharing options...
dezwez Posted January 12, 2016 Share Posted January 12, 2016 i would say check your earth points and clean them up. Sometimes see the rear brake lights dim when using indicators same sort of thing earth points can be found in the hynes manual 1 Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted January 18, 2016 Share Posted January 18, 2016 Also check connection on the fuse box in passenger footwell. Something at be loose . 1 Quote Link to comment Share on other sites More sharing options...
