Cordon Posted January 15, 2016 Share Posted January 15, 2016 Hello, I just bought a 2005 Ford Mondeo with 2.2 TDCI and its engine temperature doesn't rise above ~70 degrees mostly at the bottom on the temp gauge which is 60 degrees. Is there a problem with thermostat or something else? Are there many thermostats like BMW diesels have? Happy driving! Cordon Quote Link to comment Share on other sites More sharing options...
dezwez Posted January 15, 2016 Share Posted January 15, 2016 thermostat could be stuck open i would try a new one :) Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 15, 2016 Share Posted January 15, 2016 Mind, there are 2 thermostats. Quote Link to comment Share on other sites More sharing options...
dezwez Posted January 15, 2016 Share Posted January 15, 2016 really :) Quote Link to comment Share on other sites More sharing options...
Cordon Posted January 15, 2016 Author Share Posted January 15, 2016 Thanks for fast answers, are they hard to change? Which one i should start with or just change both? :) Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 15, 2016 Share Posted January 15, 2016 Yup there's the main one for the radiator and a second one for the oil cooler. The one for the radiator is quite easy to change, 3 bolts hold the housing on if I remember correctly. Quote Link to comment Share on other sites More sharing options...
Cordon Posted January 15, 2016 Author Share Posted January 15, 2016 Okey, but the radiator one is it harder? Or which may cause the problem? The oil cooler one is near waterpump behind intake? :) Quote Link to comment Share on other sites More sharing options...
pragmatix Posted January 15, 2016 Share Posted January 15, 2016 Change the radiator one first and it's easiest Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 15, 2016 Share Posted January 15, 2016 Yup go for the radiator one first, it's most likely to have the biggest affect on the cooling system. 30 mins should do to change it and top up. Quote Link to comment Share on other sites More sharing options...
Cordon Posted January 15, 2016 Author Share Posted January 15, 2016 Should i go genuine Ford part or some else brand? Where is it located? Can't find any good pictures of it only oil cooler ones. You guys are really great help! :) Quote Link to comment Share on other sites More sharing options...
stef123 Posted January 15, 2016 Share Posted January 15, 2016 I do prefer genuine but it's up to you. Last time I bought a stat for a 1.8 focus from ford it wasn't expensive, so should be much the same.take the plastic cover off the engine, iirc it's on the gearbox end of the engine. Quote Link to comment Share on other sites More sharing options...
dezwez Posted January 15, 2016 Share Posted January 15, 2016 remember to get some antifreeze so you can top up coolant :) 1 Quote Link to comment Share on other sites More sharing options...
Ben87 Posted January 15, 2016 Share Posted January 15, 2016 I had the same problem on my mondeo last year and it was oil cooler thermostat, I went all the way to Nottingham from Manchester and it never went above 70 degrees. Think it was about £18 from main dealer. It's something you could change yourself. But like the others said its always worth changing the radiator thermostat too. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
