Shortie Posted October 1, 2009 Share Posted October 1, 2009 Hi guys, not a sparky so after help with regards to what i have inherited. Got a K reg Mk5a cab, want to sort all the wiring out for the stereo properly, but its in a right state thanx to the previous owner. Have included pics to show the problem. Have done a table as best i can to explain, any more pics required please ask and i will do. Oh my where do i start, as you can see from the pic below, i have a mess on my hands. Between the main grey cable and the main wires they are all connected together in one way or another (scary). http://tinypic.com/r/11jopy0/4 Excuse how i word this, the metal protection that surrounds the wires inside the grey cable is connected to the brown wire attached to the top connector block. ________________________________________________________________________________ _____________________________________________________________________________ There are other bits like this that would take to much explaining, more than happy to speak over the phone if anyone has the time for a more detailed explanation. What i hope to do if possible is - can i make a fresh start and cut just after the places indicated in the photo below. http://tinypic.com/r/kc1dfo/4 Could someone confirm that the main grey cable (1) is for the Speakers and the main wires are the power and the rest (2) and what is the third cable for (3), its not the antenna as i have removed this from the display. ________________________________________________________________________________ _____________________________________________________________________________ Is this table correct - Out of the grey cable Colour wire................Role Red/yellow.................Rear Speakers positive Red/white..................Rear Speakers negative Black/white................Front speakers negative Yellow/black...............Front speakers positive Green/white................????????? Green/yellow...............????????? Brown/yellow...............????????? Brown/white................????????? There is also a metallic blue sheath with a red wire inside. Appreciate any help on this. Thanx in advance Shortie Quote Link to comment Share on other sites More sharing options...
stef123 Posted October 1, 2009 Share Posted October 1, 2009 hmm thats a mess to say the least. do you have a soldering iron and heatshrink? as for the colours im not too sure, i would rather be there to give a definet answer. the 4 cores you cant identify could also be for Speakers. you probably have front left, front right, rear left and rear right, which would explain all the cores. i would remove each of the Speakers and see what goes where. the thicker red and yellow cables are for power, permanent and switched live. the 3rd cable im not sure of. is there a fuse in the fuse panel for the cd player? i dont get why someone has botched a fuse in there... shame i wasnt closer as id certainly have come round and had a look at it for you. Quote Link to comment Share on other sites More sharing options...
mintalkin Posted October 2, 2009 Share Posted October 2, 2009 speaker wires - yellow/colour - speaker + x4 white/colour - speaker - x4 brown - earth red - perm live yellow - switched live grey/colour - illumination blue - electric ariel or amp it looks like all the speaker - wires have been wired into the earth syatem so the car body compleates the circut. hard to make out the other colour, any that i have mised please list, have fun! Quote Link to comment Share on other sites More sharing options...
The Badger Posted October 4, 2009 Share Posted October 4, 2009 Yep the speaker wires will be yellow/colour x4 and white/colour x4 as advised above, can you not just get an autoleads ISO connector as the problem seems to be after the Ford plug? Quote Link to comment Share on other sites More sharing options...
