Temp Gauge, Heater And Fan Control Switch
MooseFocus
2005 1.6 petrol Ghia
Hi people, I've had the car for a little over 2 months now and I'm trying to sort a few little niggles out.
Firstly the heat from the car is not great, I'd expect it to be a lot warmer.
Secondly the temp gauge needle don't move at all
Thirdly the fan control only works on 3 and 4
I'm assuming these are all related, can any of you put me onto some kind of fix please? Preferably nothing too technical as I'm not very competent on the spanners with modern cars
TIA
Moose
First problem sounds like thermostat is stuck open
second problem is the blower motor resistor.
Are there any how to's available for a fix that you're aware of please?
I can help with the second problem.
You need to buy another Heater resistor pack for the Focus.
To replace it you need to remove the glove box (not my video):
this shows where it is located, unplug it, two screws to un screw, then pull it out and pop the new one in.
Just done a resistor on a focus the other day. Very easy job, just access to reach in is a bit of a pain.
great - i have this issue also!!!!!
So annoying that it dosent blow out on 1 or 2!!!!
is this part expensive to buy? could anyone link me to one to purchase so i can see the right part i need
Thanks for asking this I wasn't sure if it were just me thinking it weren't working ha!
Thank you - thats really appreciated
Cheers for the headstart guys, summink for me to do at the weekend
Type that item number into eBay, that's the very resistor I was supplied to fit the other day.
That's for 2006, is that not the mk 2.5?
Are they the same?
It's for a mk2, I fitted it to a 2005 mk2. I think he has loads of them listed with different titles to catch as many punters but the part is still the same.
That's the resistor issue sorted.
Does anyone have a link to the correct thermostat please?
There's still the issue of my temp gauge not working. Possible temp sensor unit? Anyone else had an issue?
Fix the thetmostat will probably be the issue why temp gauge not registering if engine not getting warm
