cbeesley Posted January 24, 2016 Share Posted January 24, 2016 Hello, I have an issue with my 2008 Focus 2.0 TDCI.Intermittently it will start up for 1 second and then die, as though its being turned off. Try again and it starts just fine. Just wondering if anyone has seen this problem before and knows the solution ? Here is a link to a video of it having the issue.https://www.youtube....eature=youtu.beThanks Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 25, 2016 Share Posted January 25, 2016 Could be a fuel filter issue, perhaps the fuel is being starved momentarily whilst the pressure recovers. Instead of starting the car straight away, put the key in, turn the car to electrics, and wait 5 to 10 seconds, then go back to zero and repeat once more. Then try start the car. Quote Link to comment Share on other sites More sharing options...
cbeesley Posted January 27, 2016 Author Share Posted January 27, 2016 Hi, thanks for the reply. I have done this, doesn't seem to make any difference, and also changed the fuel filter and filter seal now. I have just found another thread that points me to the Anti Shudder valve, the problems sound exactly the same , so going to check this out tonight when I finish work. Fingers crossed! Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 27, 2016 Share Posted January 27, 2016 good luck! Quote Link to comment Share on other sites More sharing options...
