bertie Posted January 29, 2016 Share Posted January 29, 2016 Hi. Just recently bought a sportKa on a 2007 plate. The car has 37500 on the clock and has started giving me problems when i start the car up. The car fires up fine but a second later either stalls or nearly stalls. If it doesnt stall then i have to give a little blip of the accelerator to pull it up to normal revs. Realy sruggling to find any answers, just putting it out there to see if anyone has experienced anything similar or the same! Thanks Quote Link to comment Share on other sites More sharing options...
Dan panda Posted January 29, 2016 Share Posted January 29, 2016 Does it stall when you are below certain revs? I had a issue were i would come to a stop and put the clutch in and it would cut out and made me loose my steering. Dan Quote Link to comment Share on other sites More sharing options...
bertie Posted January 29, 2016 Author Share Posted January 29, 2016 Hi Dan. No its just on start up,seems to be when the engine is cold,its either near stallin and i have to give it a few revs, or it tatally stalls due to lack of revs?it drives spot on,its only after shes fired up?was just putting it out there to see if there were others with the same issue before sending it to the garage Quote Link to comment Share on other sites More sharing options...
simcor Posted January 29, 2016 Share Posted January 29, 2016 First thing would be change the fuel filter as it should be pretty cheap and clogged fuel filters can cause problems and don't get changed as often as they should. Second would be get it some diagnostics to see if any error codes are present. Quote Link to comment Share on other sites More sharing options...
bertie Posted January 30, 2016 Author Share Posted January 30, 2016 Cheers simcor il giv it a try 👍 Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted February 2, 2016 Share Posted February 2, 2016 I had a similar issue, which was the fuel filter housing was cracked. Quote Link to comment Share on other sites More sharing options...
