EganL Posted January 31, 2016 Share Posted January 31, 2016 Hi, I see you can buy a SD card with ford maps on it on eBay for about €50, I'm just wondering if the ford Kuga Titanium Plus will support this? My car has a location setting so I'm thinking there is no reason why the maps shouldn't load other then Ford have put a block on this happening. Quote Link to comment Share on other sites More sharing options...
alan2150uk Posted February 27, 2016 Share Posted February 27, 2016 Hi does your Kuga have Sync 2, If so you can't just add the SD card for the nav. the actually Sync unit or APIM Module would need to be swapped out for a unit that came with Nav you can't add it afterwords as it's licenced in a silly way. Ways to tell you have Nav on your Sync 2 System the Top Right corner will say insert nav sd card. and down the bottom it will have a little "i" button for information. If however it says Information in the top right corner. then you dont have the nav fuction. The Sync 2 system will report your location with GPs but this is for use with the "911 Assist" or "Emergancy Assist" in Europe. Hope this helps Quote Link to comment Share on other sites More sharing options...
alan2150uk Posted March 21, 2016 Share Posted March 21, 2016 Hi Just found this guy! He can add any fuction to the Sync 2 system! no idea how but I wish I knew.! found it on your tube he can add heated seats the LOT ! lol http://www.ford-retrofit.com/ Quote Link to comment Share on other sites More sharing options...
