donnymaac Posted February 4, 2016 Share Posted February 4, 2016 hi I got this engine malfunction warning come up on my dash I got a guy to do a quick check and he got the code p0069 map barometric pressure correlation permanent and code 042f0 unknown can anyone suggest the unknown code and is it just the p0069 map thing I need to get fixed I'm clueless thanks for any help Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted February 4, 2016 Share Posted February 4, 2016 the p0069 could be the MAP, it could also be the barometric pressure sensor tho, the error is a problem between the two figures, not specifically one or the other. it could also be electrical or mechanical which is causing the irregular readings on the sensors, the other code is new to me Quote Link to comment Share on other sites More sharing options...
artscot79 Posted February 4, 2016 Share Posted February 4, 2016 never heard of the other code either irs not a ford or generic code so ide have the codes te checked on other software Quote Link to comment Share on other sites More sharing options...
donnymaac Posted February 6, 2016 Author Share Posted February 6, 2016 thanks for your help guys Quote Link to comment Share on other sites More sharing options...
