Martp Posted February 7, 2016 Share Posted February 7, 2016 Hi can anyone tell me how I get the belt on my smax I can see it goes over the pullys and round what I think is a tensioner but I cannot see how to adjust the tensioner Quote Link to comment Share on other sites More sharing options...
iantt Posted February 7, 2016 Share Posted February 7, 2016 give us a clue what engine you have and we may be able to assist 1 Quote Link to comment Share on other sites More sharing options...
Martp Posted February 8, 2016 Author Share Posted February 8, 2016 Hi sorry its a 2.0 TDCI Quote Link to comment Share on other sites More sharing options...
iantt Posted February 8, 2016 Share Posted February 8, 2016 Tensioner is spring loaded to should self tension, but to put belt on first , you need to turn tensioner with a spanner clock wise until a 4mm hole on tensioner lines up with another hole behind, then insert a 4mm dowel in hole, this locks the tensioner so you can easily fit belt, once belt is routed and fitted , use spanner to take tension off dowel and remove dowl and let tensioner do its job. 1 Quote Link to comment Share on other sites More sharing options...
