Update Sync 2 The Easy Way
alexp999
 Share
Yep, on the russian site chipford.ru are now located other language packs for v3.10. They are not included in separate usb-installation packages but only as a standalone .zip files. I assume that we can replace the language pack inside the v.3.10 installation, edit the autoinstall.lst file and then simply install.
But yeah we need some volunteers wiling to try it on their device :)
Link to comment
Yes :) but probably all will be OK
Link to comment
Did not work with the main install file on the .ru site, Install fail at once. But then I got a link  to another 3.10 version.
Just put my language pack in it and edit the autointall.lst
All went fine until the end of the last file in my language pack. Got an install failure but all seems fine. It complained abouth not enough space.
Maybe it is necessary to remove the main language pack when adding another pack?
Everything works ok. Can´t see anything wrong.
BTW, does sync control the audio levels? I am not sure if it is a placebo effect but it seems that the audio level from the rear Speakers is a little higher than before.
Link to comment
BTW, does sync control the audio levels? I am not sure if it is a placebo effect but it seems that the audio level from the rear speakers is a little higher than before.
Put here Yours autoinistall here . Lets look
Link to comment
;         Microsoft Windows Automotive
;         USB Installation Directive File
;         3.10 (15180) Update from:
;         10308,10337,11038,11063,11081,11134
;         12023,12047,12058,12156,12285,13164,
;      13171, 13213, 13249, 13269, 13283, 13284, 13309, 13312
;      14073, 14122, 15042, 15050, 15085, 15091, 15109, 15128
;         Other versions not supported
;         autoinstall.lst (EU-Lang pack2 EN-GB_PL-PL_DE-DE_RU-RU)
;         FORD EXPERTS
;;; The following tags are software versions supported by this update
[SYNCGen2_4.23.11038]
[SYNCGen2_4.23.11063]
[SYNCGen2_4.23.11081]
[SYNCGen2_4.23.11134]
[SYNCGen2_4.26.12023]
[SYNCGen2_4.28.12156]
[SYNCGen2_4.29.12285]
Item1 = BT4T-14D546-EE
Open1 = SyncMyRide\BT4T-14D546-EE.cab
Item2 = EA5T-14D546-AKB
Open2 = SyncMyRide\EA5T-14D546-AKB.cab
Item3 = EA5T-14D546-HB
Open3 = SyncMyRide\EA5T-14D546-HB.cab
Item4 = EA5T-14D546-ACB
Open4 = SyncMyRide\EA5T-14D546-ACB.zip
Item5 = BT4T-14D546-FB
Open5 = SyncMyRide\BT4T-14D546-FB.cab
Item6 = EA5T-14D546-AHB
Open6 = SyncMyRide\EA5T-14D546-AHB.cab
Item7 = EA5T-14D546-ADB
Open7 = SyncMyRide\EA5T-14D546-ADB.cab
Item8 = EA5T-14D546-AEB
Open8 = SyncMyRide\EA5T-14D546-AEB.cab
Options = AutoInstall
;;; This tag runs only on Zodiac pre-release tags
[SYNCGen2_4.30.13171]
[SYNCGen2_4.32.14073]
[SYNCGen2_4.32.14122]
[SYNCGen2_3.08.15042]
[SYNCGen2_3.08.15050]
[SYNCGen2_3.08.15085]
[SYNCGen2_3.08.15091]
[SYNCGen2_3.08.15109]
[SYNCGen2_3.08.15128]
Item4 = BT4T-14D546-FB
Open4 = SyncMyRide\BT4T-14D546-FB.cab
Item5 = EA5T-14D546-AHB
Open5 = SyncMyRide\EA5T-14D546-AHB.cab
Item6 = EA5T-14D546-ADB
Open6 = SyncMyRide\EA5T-14D546-ADB.cab
Item7 = EA5T-14D546-AEB
Open7 = SyncMyRide\EA5T-14D546-AEB.cab
;;; The following are the 3.10.16180 image files
[SYNCGen2_3.10.16180]
Item1 = EA5T-14D546-AFB
Open1 = SyncMyRide\EA5T-14D546-AFB.cab
Item2 = DM5T-14D621-AB
Open2 = SyncMyRide\DM5T-14D621-AB.CAB
Item3 = EA5T-14D546-DF
Open3 = SyncMyRide\EA5T-14D546-DF.ZIP
Item4 = EA5T-14D546-FE
Open4 = SyncMyRide\EA5T-14D546-FE.ZIP
Item5 = EA5T-14F496-AE
Open5 = SyncMyRide\EA5T-14F496-AE.ZIP
Item6 = EA5T-14F497-CF
Open6 = SyncMyRide\EA5T-14F497-CF.ZIP
Item7 = EA5T-14F657-AG
Open7 = SyncMyRide\EA5T-14F657-AG.ZIP
Item8 = EA5T-14D546-AGB
Open8 = SyncMyRide\EA5T-14D546-AGB.cab
Item9 = BT4T-14D546-EE
Open9 = SyncMyRide\BT4T-14D546-EE.cab
Item10 = EA5T-14D546-LB
Open10 = SyncMyRide\EA5T-14D546-LB.cab
Item11 = EA5T-14F497-EF_64706
Open11 = SyncMyRide\EA5T-14F497-EF_64706.zip
;;; This tag runs only if none of the other tags match
[SYNCGen2_All]
Item2 = EA5T-14D546-NB
Open2 = SyncMyRide\EA5T-14D546-NB.cab
Link to comment
You change this ?
Link to comment
aa You add next language package ... but why ?
Link to comment
2 minutes ago, vincentka said:
You change this ?
in the  The following are the 3.10.16180 image files part
(my language pack)
Link to comment
Not sure what happend if I removed something so I just add an item11
Link to comment
EA5T-14F497-CF is language pack ........ only replace for Your country package :)
Link to comment
Ah, ok. But can I flash it again?
Link to comment
Not needed now :D
Link to comment
Hello, could i get a download link for the 3.10 version? thank you!
  • Like 1
Link to comment
Could I get a link as well please? I have a 2015 focus titanium x, with satnav - not sure if that makes any difference.
Thanks!
  • Like 1
Link to comment
Many thanks for the chance at installing this update, I installed it on to my Mondeo 2015 with nav and all seems to work fine.  As others have said, it took roughly 30mins with various reboots and all was up and running.  Have not properly tested out sat nav yet but will come back and chime in once I do.
Thanks again!
  • Like 1
Link to comment
Could you send me the link to update my SYNC 2 system for my 2016 Ford Focus Titanium X with navigation.
Many Thanks
  • Like 1
Link to comment
Can you send me the link to update to v3.10 please?
Tia
Link to comment
Tia
look UP
Link to comment
On 6.03.2017 at 7:12 PM, vincentka said:
Here You have language packages
Link to comment
4 hours ago, vincentka said:
Sync2 USB update package to 3.10 (16180) version for North America
EU_LANGUAGE PACKAGE
Please look inside autoinstall :):yahoo:
First of all thank you very much for your work
I'm from South America and I have a Fiesta Titanium with Sync2 (15128) made in Mexico. I'm almost sure that this factory is the one that makes the Fiesta for the North American market as well. So do you think I will be fine using the update you provided + the South American language pack listed on chipford.ru?
If so, how should I install that language pack? Should I change
Item7 = EA5T-14F497-AE
Open7 = SyncMyRide\EA5T-14F497-AE.ZIP
To match the language pack downloaded from chipford.ru?
Regards,
Link to comment
Bannko thanks for sending me the latest update for Sync2. I downloaded and extracted the update onto a pen drive formatted to Fat32.
The pen drive now contains a file called Gen2v310build1681updatepackageEULlangpack2, when this file is opened its got two other called:-
a) SyncMyRide
b) autoinstall.lst
Is this correct ?
Is it just a case now of inserting the pen drive and do the update.
Link to comment
a) SyncMyRide
b) autoinstall.lst
Is this correct ?
Hi Norton,
exactly...just the same procedure as with the previous update. Please check the firs post of this thread. :)
Link to comment
Regards,
Yest, thanks to the links that Vincentka has provided to us. You should only download the language pack, copy it into the v3.10 update "SyncMyRide" folder and change the language pack in autoinstall.lst accordingly.
Link to comment
:) :yahoo:
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
