Storm16 Posted February 14, 2016 Share Posted February 14, 2016 Hi all got what looks like oil behind clutch pedal and dripping onto floor matt any ideas on problem and cost.thanks Quote Link to comment Share on other sites More sharing options...
Russ Posted February 14, 2016 Share Posted February 14, 2016 The master clutch cylinder on the pedal is leaking and needs renewed. 1 Quote Link to comment Share on other sites More sharing options...
Storm16 Posted February 14, 2016 Author Share Posted February 14, 2016 Thanks is it a expensive job? Quote Link to comment Share on other sites More sharing options...
Ryan_Tango Posted February 14, 2016 Share Posted February 14, 2016 27 minutes ago, Storm16 said: Thanks is it a expensive job? You're looking about between £120 - £200 1 Quote Link to comment Share on other sites More sharing options...
Russ Posted February 14, 2016 Share Posted February 14, 2016 37 minutes ago, Storm16 said: Thanks is it a expensive job? To be Honest, I'm not sure but last year the mk6 fiesta I had needed the master cylinder done and it cost me £160 at a garage! its 'do-able' yourself.....the cylinder won't be too costly depending where you get it, have a look here for the method http://www.justanswer.com/uk-ford/3cv5o-hi-need-change-clutch-master-cylinder.html#re.v/511/ 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted February 14, 2016 Share Posted February 14, 2016 Note that the hydraulic clutch uses brake fluid and not oil. Brake fluid is corrosive so you should solve the problem as soon as possible and clean the floor matt and if it is a big leak also the carpet. If there is a big leak and the brake fluid reaches the floor pan it will dissolve the paint and cause the floor pan to corrode. 2 Quote Link to comment Share on other sites More sharing options...
