rh205 Posted February 15, 2016 Share Posted February 15, 2016 Hi, I am trying to hardwire my dash cam into my car and have a bit of a problem and would like some tips or advice. The problem is the earthing point appears to be right within the dash behind the fuse box on the firewall. The thing is I need to access this to connect the earth wire of the camera. However once I get my hands in the dash and close to this point it is impossible to see what I am doing. I wonder if anyone knows what sort of tools to use to ease the job of connecting the cameras ground wire without getting my hands in the way. Quote Link to comment Share on other sites More sharing options...
karl46 Posted February 15, 2016 Share Posted February 15, 2016 Drill a new hole in the side of the "A" post and connect earth wire with a self tapping screw. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted February 15, 2016 Share Posted February 15, 2016 There are usually loads of grounding points, any metal screw will usually do. 2 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted February 15, 2016 Share Posted February 15, 2016 +1 Any body mounted screw or bolt will suffice. 1 Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted February 17, 2016 Share Posted February 17, 2016 I took mine to a garage to have this done, but they attached the earth wire to a bolt just above the fuse box. 1 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 17, 2016 Share Posted February 17, 2016 Attached mine to on one near the door sill with some other earths, easy access. 1 Quote Link to comment Share on other sites More sharing options...
jace1969 Posted February 17, 2016 Share Posted February 17, 2016 Nut just above fuse box,might be something like a 10 or 12mm as i forgot but i have 2 on these nuts as i could see 2 off them.tracker and dash cam,both work A1. Quote Link to comment Share on other sites More sharing options...
