sogrady Posted February 18, 2016 Share Posted February 18, 2016 I have a ford fiesta LX 1.3 03 i went out a little while ago and it suddenly started juddering and engine management light kept flashing. parked it and got back in it to take it home a few hours later and the engine management light came on and stayed on, it was still juddering on the way home. It was plugged in and i was told cylinder 2 misfiring advised to change the spark plugs, coil pack & ht leads which i did, this didn't work, so i changed the cam shaft sensor, crank shaft sensor and had all new pipes put in as well as i was recommended to do this! after having all this changed it goes to start up but then cuts out, if i was to press the acceleration pedal when turning the ignition the car would start if i was to rev it really high but as soon as my foot comes off the acceleration pedal or if i only done small revs it cuts out again I am running out of ideas! has any one got any idea what it could be or has anyone experienced anything similar?! Quote Link to comment Share on other sites More sharing options...
stef123 Posted February 18, 2016 Share Posted February 18, 2016 If your getting a good spark, then I'd start looking at injectors and cylinder compression. 1 Quote Link to comment Share on other sites More sharing options...
