mills705 Posted February 19, 2016 Share Posted February 19, 2016 Having read a few other forum posts at the moment. I was wondering how long do you guys wait before turning the engine off if you own the ecoboost? As it seems you should leave it to cool before turning off? I generally just park up, handbrake and then engine off with little time for the turbo to cool. Is that enough? How does this work with start/ stop being present?! Quote Link to comment Share on other sites More sharing options...
arob.sco Posted February 19, 2016 Share Posted February 19, 2016 Oh I've never heard that before, I just park up in my driveway start/stop kicks in and I turn off the engine and lock the car. Is this a nono? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
MONDEO TXS 2.2 Posted February 19, 2016 Share Posted February 19, 2016 The practice of allowing a turbo to cool a little before switching off the engine is as old as time itself - these little ecoboosts spin the turbo @ around 250,000 max' r.p.m. & get literally red hot - so although some will say it's not required - it cannot do any harm Quote Link to comment Share on other sites More sharing options...
JSMarsden Posted February 19, 2016 Share Posted February 19, 2016 TBH the engines etc are built to be turned off etc sraight away. I simply pull up and turn the engine off - even if its after a 300mile drive. Never thought about having to leave anything to cool as the fan stays on for a while anyway when ive walked away Quote Link to comment Share on other sites More sharing options...
mikeyd1 Posted February 19, 2016 Share Posted February 19, 2016 I leave for extra 10 seconds before switching off and 1 min if i been driving hard 1 Quote Link to comment Share on other sites More sharing options...
cjay1 Posted February 19, 2016 Share Posted February 19, 2016 no need fan and water pump will keep going after switch off if further cooling is required. engine should be at tick over befour switching off if start stop hasnt already kicked in Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted February 19, 2016 Share Posted February 19, 2016 If you've got stop-start, it'll be switching off immediately with that several times a day anyway... 1 Quote Link to comment Share on other sites More sharing options...
MarksST Posted February 19, 2016 Share Posted February 19, 2016 It's not about cooling the turbo, it's about keeping it supplied with oil, sitting idling won't cool the engine down. turning the engine off when the turbo is at a high speed will mean it spins for a long time with no oil flow, if you drive off boost for a bit or idle for a few seconds before switching off this allows the turbo to slow down, the time with no oil flow is then reduced. 2 Quote Link to comment Share on other sites More sharing options...
