rear camber problem
supercmaxer
Evening all,
I lowered my cmax over a year ago, i had to change one of the rea suspension arms as I couldnt get the bolts out and had it cut off.
I replaced it with a non ford arm and now or since then the n/s rear camber is in more than other side.  It been set up correctly using hunter 4 whee alignment twice and its been on another
system again all correctly set up and within tolerances.
Would the non ford suspension arm be causing the problem?
thanks
camber is not adjustable, so sounds like the arm is not the same length as the old one.
arnt the two inner bolts the camber adjusters?
nope, they adjust the rear wheel alignment(rear tracking)
New arm I guess then.
sounds like it, can you measure the arm length compared to the other side?
