4x4monster Posted March 9, 2016 Share Posted March 9, 2016 Hi, im new to this forum and need some help. My 2011 fiesta 1.25 has an annoying problem where the battery light keeps coming on, mostly on longer drives. it's been like this for a while but the car has always been fine apart from the light. While driving at the weekend the light came on again but this time more lights came on and the car started to drive weird (power steering and ABS stopped working) Stopped the car and turned it off, when trying to restart the battery was flat. I have had this happen before in a previous car so I assumed it was a faulty alternator. after jump starting the car everything worked fine again and the battery light was off. I checked the alternator output and was getting 14.5v with the car at idle. I thought it must have an intermittent fault so I got the alternator changed yesterday. Driving to work again this morning the light has come back on so it's not the alternator. If anyone has any idea what could be wrong, I would be grateful for any help. Quote Link to comment Share on other sites More sharing options...
JamesV Posted March 9, 2016 Share Posted March 9, 2016 Have you checked the battery ? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Obnoxious Posted March 9, 2016 Share Posted March 9, 2016 You've already replaced the alternator? Ouch, that must have been an expensive job. Did you check your battery first? It could be leaking or losing charge. Perhaps all you need is a new battery? Batteries are not maintenance free, they need to be replaced when the battery can no longer hold a full or adequate charge. All the best. :) P.S. Welcome to the forum, it's great to have another owner here. Quote Link to comment Share on other sites More sharing options...
iantt Posted March 9, 2016 Share Posted March 9, 2016 sounds like a wiring issue of the smartcharge system , the plug with the thin wires needs inspecting. Quote Link to comment Share on other sites More sharing options...
4x4monster Posted March 11, 2016 Author Share Posted March 11, 2016 Thanks for the suggestions, the battery is brand new, do all fiestas have smart charge? I thought it would have a 3 pin plug on the alternator, mine only has a single thin wire? Quote Link to comment Share on other sites More sharing options...
Matthewgray Posted March 24, 2016 Share Posted March 24, 2016 did you get anywhere with this i have the same problem and single wire alternator Quote Link to comment Share on other sites More sharing options...
E5GDM Posted March 26, 2016 Share Posted March 26, 2016 I take it you got a brand new alternator, so check earth leads, & battery connections are clean & tight. If that's all ok get an auto electrition to check the battery out put. Quote Link to comment Share on other sites More sharing options...
Kyle1991 Posted November 21, 2018 Share Posted November 21, 2018 Hi 4x4monster did you get a fix for this vehicle? I have one doing the exact same problem thanks kyle Quote Link to comment Share on other sites More sharing options...
Rowbo Posted March 12, 2019 Share Posted March 12, 2019 Hi guys Just wondering if somebody could help me.. My car has been perfectly fine (12 plate ford fiesta) running all up and well. I did a 10 minute drive today, parked up, and then turned the ignition off. Once it turned off the warning light came on for the battery sign. However, when i am actually driving the warning light no longer appears. This just comes when ive turned the ignition off. Any suggestions on what i should do? Thinking i need to take it to the garage this weekend if it doesnt pack up by then!? Quote Link to comment Share on other sites More sharing options...
4x4monster Posted November 14, 2019 Author Share Posted November 14, 2019 On 11/21/2018 at 10:48 PM, Kyle1991 said: Hi 4x4monster did you get a fix for this vehicle? I have one doing the exact same problem thanks kyle Hi, not been on here for a while. Yes it was the split on the thin cables going to the alternator. Wire repaired and has been fine ever since. Quote Link to comment Share on other sites More sharing options...
Wayne armstead Posted June 2, 2020 Share Posted June 2, 2020 Hi there I have a 2004 3dr mk6 fiesta I have changed the battery the alternator and all the belts and I have still got my battery light on my dashboard is there a way to remove it by resetting the ecu at all Quote Link to comment Share on other sites More sharing options...
KCENTLE Posted August 16, 2020 Share Posted August 16, 2020 Hi Family, I have a battery issue, yesterday I bough full service kit and replaced my brake pads. I took my 2011 FORD Fiesta for 186 000 service and they changed the plugs. Tonight when I drive the car, the battery lights came on and when I change gears there's a kick movement, what could that be? I replaced my battery last year. Quote Link to comment Share on other sites More sharing options...
