Bevsh Posted March 10, 2016 Share Posted March 10, 2016 Hello, could anyone advise me?? My street ka indicator lights won't turn off unless the battery is disconnected !! Has anyone had this problem ? And any ideas what to do Thankyou Quote Link to comment Share on other sites More sharing options...
Omendata Posted March 10, 2016 Share Posted March 10, 2016 Faulty relay or ground issue - either way you are going to have to get out the multimeter or leccie probe! Easiest thing to check first would be the indicator switch/stalk. Do you meaN when you disconnect the battery the indicators are off when its plugged back in? If it does then it will be the relay/ground and if they come back on when the battery is plugged back in i would test the indicator switch first! Quote Link to comment Share on other sites More sharing options...
iantt Posted March 10, 2016 Share Posted March 10, 2016 alarm Quote Link to comment Share on other sites More sharing options...
