mk2.5 reverse light intermittent
MurdoD
 Share
Not sure what's going on but my reverse light rarely works. It's not the bulb as that was changed and non difference. I had written it off as busted completely until it did randomly come on one night... and then again a few nights later. I believe this rules out fuses and bulb... could  be wiring or contacts somewhere?
Link to comment
Noticed my sons doing the same. where is the switch, thanks. Every time I see him pull up no reverse lights, so tell him he says they are workong:wacko:
Link to comment
Sounds lime the switch to me aswell, it's on the top of the gearbox there are two different types long one with triangle shaped connector and a short square shaped connector. To test the switch remove the connector and put a wire between the two pins with the ignition on if the light works then the switch is to blame.
Mike
  • Like 1
Link to comment
  • 2 months later...
Sorry to ressurect, just wanted to say thanks for the pointer on the switch. Exactly what it was, been working perfectly since gettin that replaced.
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
