Tezza Posted March 17, 2016 Share Posted March 17, 2016 Just now, mayo10uk said: Hi Tezza, no what am I looking for and where ? Sent from my iPhone using Ford OC You will not have the input like on the pfl the set up on the fl with sync2 is totally different Quote Link to comment Share on other sites More sharing options...
mayo10uk Posted March 17, 2016 Share Posted March 17, 2016 I see ! Well please keep me updated I'd love to add a camera to mine. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Tezza Posted March 17, 2016 Share Posted March 17, 2016 8 minutes ago, mayo10uk said: Hi Tezza, I did see a program that you can enable on 2015 + vehicles using a elm cable. Please keep me updated ! I would very much like to add this feature my last focus had it and regret not having it now :-( instead I opted for a city pack. Sent from my iPhone using Ford OC I have the UCDS adaptor and programme and this covers alot of fords inc the 2015 focus :) Yes will keep you updated as fingers crossed it will be up and running tomorrow as we have fitted the camera and new loom just needs activating Quote Link to comment Share on other sites More sharing options...
mayo10uk Posted March 17, 2016 Share Posted March 17, 2016 Excellent ! Not a cheap cable. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
MurdoD Posted March 17, 2016 Author Share Posted March 17, 2016 Won't it void his warranty going 3rd party rather than OEM? he really doesn't want any kind of unofficial wiring/modules/hacks etc.. If he can't have genuine he won't want it. Appreciate all the feedback thought.. making me wonder about doing my mk2.5... hmmmm Quote Link to comment Share on other sites More sharing options...
mayo10uk Posted March 23, 2016 Share Posted March 23, 2016 Any joy Tezza? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
rocket_111 Posted March 30, 2016 Share Posted March 30, 2016 Any update on this?... Quote Link to comment Share on other sites More sharing options...
Tezza Posted May 26, 2016 Share Posted May 26, 2016 On 22/03/2016 at 8:09 PM, mayo10uk said: Any joy Tezza? Sent from my iPhone using Ford OC Update I have successfully fitted a oem reverse camera to my workmates ST Mk3.5 TDCI :) 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted June 4, 2016 Share Posted June 4, 2016 finally got round to fitting reverse camera to my mk3, fairly straight forward, only issue i had was with my elm327, didnt have ms can switch to be able to initialise the display, so resoldered the hs can wires to ms can positions temporary to complete the task. sorted, quite good camera considering it was a cheap chineese one off eBay 3 Quote Link to comment Share on other sites More sharing options...
Tezza Posted June 5, 2016 Share Posted June 5, 2016 Looks great which camera did you go for ? and how long did it take the Russians to send out the adaptor :) Quote Link to comment Share on other sites More sharing options...
iantt Posted June 5, 2016 Share Posted June 5, 2016 hi, used the camera that you posted up linked to eBay. the camera is the ntsc version and works fine. the module and adapter cable came from russian guy, took only 10 days to arrive which i thought was not bad. 1 Quote Link to comment Share on other sites More sharing options...
rocket_111 Posted June 13, 2016 Share Posted June 13, 2016 On 26/05/2016 at 7:15 PM, Tezza said: Update I have successfully fitted a oem reverse camera to my workmates ST Mk3.5 TDCI :) Nice one, did you use the russian adaptor to get it to work for the mk3.5? Quote Link to comment Share on other sites More sharing options...
nickp1975 Posted June 15, 2016 Share Posted June 15, 2016 have you got a link for the russan adapters? Do you need the ford programming software? Quote Link to comment Share on other sites More sharing options...
iantt Posted June 15, 2016 Share Posted June 15, 2016 http://www.ucdsys.ru/ email him at kamurzaev@gmail.com. you will need focccus software to enable camera function 2 Quote Link to comment Share on other sites More sharing options...
Tezza Posted June 15, 2016 Share Posted June 15, 2016 On 13 June 2016 at 8:37 PM, rocket_111 said: Nice one, did you use the russian adaptor to get it to work for the mk3.5? Yes I did and you will also need to buy the full programme licence to activate the camera as FoCCCus program does not have the second part that needs enabling :( 24 minutes ago, iantt said: http://www.ucdsys.ru/ email him at kamurzaev@gmail.com. you will need focccus software to enable camera function As above Terry Quote Link to comment Share on other sites More sharing options...
iantt Posted June 15, 2016 Share Posted June 15, 2016 whats the seconc bit that needs enabling for mk3.5? Quote Link to comment Share on other sites More sharing options...
Tezza Posted June 16, 2016 Share Posted June 16, 2016 21 hours ago, iantt said: whats the seconc bit that needs enabling for mk3.5? FoCCCus does not have direct configuration in ts programme as you need to change the Block the Config DE00 - DE00 to enable the APIM Quote Link to comment Share on other sites More sharing options...
Tristan82 Posted June 7, 2017 Share Posted June 7, 2017 Would this wire do the same thing as the module from Russia, there is a video on it to if you go on YouTube Quote Link to comment Share on other sites More sharing options...
Tristan82 Posted June 7, 2017 Share Posted June 7, 2017 On 04/06/2016 at 7:06 PM, iantt said: finally got round to fitting reverse camera to my mk3, fairly straight forward, only issue i had was with my elm327, didnt have ms can switch to be able to initialise the display, so resoldered the hs can wires to ms can positions temporary to complete the task. sorted, quite good camera considering it was a cheap chineese one off ebay What happens if you press the p pilot button at the bottom of the screen Quote Link to comment Share on other sites More sharing options...
iantt Posted June 7, 2017 Share Posted June 7, 2017 nothing on mine. Quote Link to comment Share on other sites More sharing options...
